Problem with AP placements changing in Prime Map
wifiguy1000
All,
     I've loaded APs into a large area map.  After adding APs and saving, occassionally after a few hours 1-3 of the APs will spontaneously move on the map, appearing to dissappear.  When I search for their specific names, I'll notice their x y's are matching another APs and for some reason they've piggy backed.  I have done nothing, it's happening on its own.  Anyone have experience with this bug in Prime 1.3?  If so any suggestions for resolving this issue?  To say its annoying would be an understatement.
Thanks again!
- John
mohanak
Heat map is showing wrong positions in the PI 1.3
CSCuh11786
Symptom:
Prime Infrastructure may display devices in the wrong position when there are more than 15 access points on the floor.
Conditions:
Workaround:
At this time, there is no workaround.
Last Modified:
Jan 28,2014
Status:
Other
Severity:
3 Moderate
Product:
Network Level Service
Known Affected Releases:
(1)
1.3(0.20)
