AP communication via Port udp 16670
jan.kunze
Hi there,
we are using an new 9800 WLC with old 28xx and new 91xx APs. After some time we noticed UDP traffic hitting our firewall on Port 16670 between some differnt APs. I was not aware that APs "talk" to each other. Is this normal behavior?
The usual communication is between the WLC and the AP back and forth.
Thanks in Advance
Jan
6 Replies 6
Scott Fella
AP's from what I know, only talks to the controller.  There is a old port matrix out there for ports used by various wireless devices and 16670 is not one of them.
-Scott
jan.kunze
Hi Scott,
thanks for your information. I found this old matrix, its' from the 5508 Series. In this Matrix the UDP Port 16670 is mentioned but only in the communication between AP and WLC.#
https://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/113344-cuwn-ppm.html
Anyone has an idea?
That is the matrix I was talking about.  This port is not used by Cisco, you can look up that port.  If this is something that you want to diagnose more, then I would say either open a TAC case, or block that port on your FW and see what happens.  AP's do not communicate to each other, they communicate back to the controller.
-Scott
Reinvtv
We are running into the same issue.
Have you found anything about this?
Apr  5 2022 09:06:49.781 CEST: %SEC-6-IPACCESSLOGP: list ACL-IN-VJL103-CLN-Wireless denied udp 10.48.34.36(5261) (Vlan103 009e.00c2.0400) -> 10.48.66.50(16670), 6 packets
Apr  5 2022 09:06:49.781 CEST: %SEC-6-IPACCESSLOGP: list ACL-IN-VJL103-CLN-Wireless denied udp 10.48.34.35(5250) (Vlan103 009e.00be.0000) -> 10.48.66.50(16670), 3 packets
Apr  5 2022 09:06:49.781 CEST: %SEC-6-IPACCESSLOGP: list ACL-IN-VJL103-CLN-Wireless denied udp 10.48.34.36(5261) (Vlan103 009e.00be.0000) -> 10.48.66.50(16670), 6 packets
Apr  5 2022 09:06:49.781 CEST: %SEC-6-IPACCESSLOGP: list ACL-IN-VJL103-CLN-Wireless denied udp 10.48.34.36(5261) (Vlan103 009e.00be.0000) -> 10.48.66.47(16670), 3 packets
Apr  5 2022 09:06:49.781 CEST: %SEC-6-IPACCESSLOGP: list ACL-IN-VJL103-CLN-Wireless denied udp 10.48.34.36(5261) (Vlan103 009e.00c2.0400) -> 10.48.66.47(16670), 2 packets
Apr  5 2022 09:06:49.781 CEST: %SEC-6-IPACCESSLOGP: list ACL-IN-VJL103-CLN-Wireless denied udp 10.48.34.35(5250) (Vlan103 009e.00c2.0400) -> 10.48.66.50(16670), 2 packets
Apr  5 2022 09:06:54.572 CEST: %SEC-6-IPACCESSLOGP: list ACL-IN-VJL103-CLN-Wireless denied udp 10.48.34.35(5250) (Vlan103 009e.00c2.0400) -> 10.48.66.38(16670), 1 packet
(We are blocking inter-switch traffic on our vlans, that is how we noticed in the first place)
(both IP's are Access points, but on different switches (but physically close to each other)
Rich R
Thanks @Alejandro Ramirez Gomez can you ask WNBU devs for more info on exactly what "client policies" is or does?  What are the APs communicating to each other?
