AP discovery problem on VLAN 3
ccsam
Level 3
Level 3
I did setup BBSM 5.2 with internal interface on VLAN3 and all my network element are on VLAN 3 as well. When I run discovery wizards, it said snmp not corrent. I double check on the snmp string, all matches. I did key in VLAN 3 during discovery process.
regards,
smahbub
Level 11
Level 11
Did you try running the TRACE functionality to troubleshoot this problem?? If not try that, for more details check the following URL
http://www.cisco.com/en/US/customer/products/sw/netmgtsw/ps533/products_user_guide_chapter09186a008019228b.html#11436
