AP do not find Controller
vmhoang2
Visitor
I have issue, AP disconnect Controller C9800 and It rejoin controller. I remote SSH to AP and see that It send request to Controller, but Controller do not response ( WLC not found).
AP run PPoe, so I never power inline on switch and It reboot. After AP send discovery to Controller and Controller response.I have tried troubleshooting, but don't know what the cause is.
Has anyone encountered this problem? help me !!!
14 Replies 14
Mark Elsen
 - (include AP model , controller model and software version being used on the C9800 too)
 - Have a checkup of the C9800 current configuration with the CLI command show tech wireless ; feed the output into
        Wireless Config Analyzer
 - Check controller logs too when the AP tries to join
 - Use these tools to further debug the AP join problem : https://logadvisor.cisco.com/logadvisor/wireless/9800/9800APJoin
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Hi Marce 1000,
Wireless controller is behind a NAT device and  Wireless Controller manages only Access Points reachable through the public internet (external APs). I configuration Controller in the CAPWAP discovery response to both the public IP and the private IP.
Could this cause a discovery error or could it have any impact?
 - APs must have an access path to the controller , make sure that is not blocked by firewalling (e.g.) ; simple test could be to try to ping the controller from an external AP.
 M.
AP can ping to Wireless controller and Firewall open  port upd 5246 and 5247.
                 >...AP can ping to Wireless controller and Firewall open  port upd 5246 and 5247.
  As mentioned before look into : https://logadvisor.cisco.com/logadvisor/wireless/9800/9800APJoin
 M.
Show wireless state ap join summary
Share this here
Hi NMH,
Yes it can be NAT issue ,
do you use NAT 1:1 or port forwarding?
i used Nat 1:1.
 I have enabled capwap debug application events. I have seen AP send discovery to controller both public and private ip. But the Controller is not responding. Then I turned off POE on the SWitch and turned it back on. The AP reboots, sends the discovery to the controller, and Controller  responds.
Now the AP joins the Controller.
I still don't understand why this problem occurs.
When it happened again check NAT translate in fw is it add or not.
Also how ap discover wlc IP via dhcp or dns?
Yes,
AP discovery WLC ip, I used command Capwap ap primary-base on each APs.
Let make second look to issues
Why shut no shut porr make connection success?
Wlc is behind NAT and it use public IP but sure AP not use public IP
It use private and hence AP also behind NAT, this NAT is dynamic I think and it have absolute times when end the NAT is remove and this make wlc receive packet from new AP port source.
Make udp nat timeout of AP is long enough.
MHM
That's a great explanation.
I want to recreate that environment. Can you give me direction to solve that problem.
Rich R
If the AP joins after power cycle then you've hit a software bug which was preventing join.
Make sure your WLC software is up to date as per TAC recommended link below - currently 17.9.4 + SMUs + APSP6.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
