AP does not join WLC.
Hi.
The AP tries to join the WLC, but the session does not appear to be established.
Attach debug content.
May 11 08:13:09 kernel: [*05/11/2021 08:13:09.8076] CAPWAP State: Discovery
May 11 08:13:09 kernel: [*05/11/2021 08:13:09.8076] Discovery Request sent to 172.29.22.12, discovery type STATIC_CONFIG(1)
May 11 08:13:09 kernel: [*05/11/2021 08:13:09.8176] Discovery Request sent to 172.29.22.12, discovery type STATIC_CONFIG(1)
May 11 08:13:09 kernel: [*05/11/2021 08:13:09.8575] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
May 11 08:13:09 kernel: [*05/11/2021 08:13:09.8575] Discovery Response from 172.29.22.12
May 11 08:13:10 kernel: [*05/11/2021 08:13:10.0575] systemd[1]: Starting dhcpv6 client watcher...
May 11 08:13:10 kernel: [*05/11/2021 08:13:10.0775] systemd[1]: Stopping DHCPv6 client...
May 11 08:13:10 kernel: [*05/11/2021 08:13:10.1475] systemd[1]: Starting DHCPv6 client...
May 11 08:13:10 kernel: [*05/11/2021 08:13:10.2474] systemd[1]: Started DHCPv6 client.
May 11 08:13:10 kernel: [*05/11/2021 08:13:10.3974] systemd[1]: Started dhcpv6 client watcher.
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0000]
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0000] CAPWAP State: DTLS Setup
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0000] dtls_cssl_msg_cb: Received >>> DTLS Header [Length 000d]
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0000] dtls_cssl_msg_cb: Received >>> DTLS 1.2 Handshake [Length 00ac] ClientHello
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0000] dtls_connectionDB_add_connection: Added Connection 0x2b4e2c00 Server [172.29.22.12]:5246 Client [172.29.22.158]:5248
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0000] create_dtls_connection: Creating DTLS Ctrl Connection 0x2b4e2c00
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0000] local_in_addr_comp: Client and server addresses/port/version of 2 nodes are [172.29.22.158]:5248(0)--[172.29.22.12]:5246(0) [172.29.22.158]:5248--[172.29.22.12]:5246
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0000] dtls_connection_find_using_link_info: Searching connection [172.29.22.158]:5248--[172.29.22.12]:5246, result 0x2b4e2c00
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0000] dtls_cssl_msg_cb: Sent <<< DTLS Header [Length 000d]
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0000] dtls_cssl_msg_cb: Sent <<< DTLS 1.2 Handshake [Length 002f] HelloVerifyRequest
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0000] dtls_cssl_msg_cb: Received >>> DTLS 1.2 Handshake [Length 00cc] ClientHello
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0000] dtls_process_packet: SSL get error rc 5
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0000] dtls_cssl_msg_cb: Sent <<< DTLS 1.2 Handshake [Length 005e] ServerHello
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0000] dtls_cssl_msg_cb: Sent <<< DTLS 1.2 Handshake [Length 048a] Certificate
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0000] dtls_cssl_msg_cb: Sent <<< DTLS 1.2 Handshake [Length 0067] CertificateRequest
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0000] dtls_cssl_msg_cb: Sent <<< DTLS 1.2 Handshake [Length 000c] ServerHelloDone
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0000] dtls_cssl_msg_cb: Received >>> DTLS 1.2 Handshake [Length 0485] Certificate
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0099] dtls_cssl_msg_cb: Received >>> DTLS Header [Length 000d]
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0099] dtls_cssl_msg_cb: Received >>> DTLS 1.2 Handshake [Length 010e] ClientKeyExchange
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0199] dtls_cssl_msg_cb: Received >>> DTLS Header [Length 000d]
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0199] dtls_cssl_msg_cb: Received >>> DTLS 1.2 Handshake [Length 0110] CertificateVerify
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0199] dtls_cssl_msg_cb: Received >>> DTLS 1.2 ChangeCipherSpec [Length 0001]
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0199] dtls_cssl_msg_cb: Received >>> DTLS 1.2 Handshake [Length 0018] Finished
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0199] dtls_process_packet: SSL get error rc 5
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0199] local_in_addr_comp: Client and server addresses/port/version of 2 nodes are [172.29.22.158]:5248(65277)--[172.29.22.12]:5246(65277) [172.29.22.158]:5248--[172.29.22.12]:5246
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0199] dtls_connection_find_using_link_info: Searching connection [172.29.22.158]:5248--[172.29.22.12]:5246, result 0x2b4e2c00
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0199] dtls_cssl_msg_cb: Sent <<< DTLS Header [Length 000d]
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0199] dtls_cssl_msg_cb: Sent <<< DTLS 1.2 ChangeCipherSpec [Length 0001]
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0199] dtls_cssl_msg_cb: Sent <<< DTLS 1.2 Handshake [Length 0018] Finished
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0699] dtls_load_ca_certs: LSC not enabled
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0799] dtls_verify_con_cert: serverAuth not set in Controller certificate!
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0799] dtls_verify_con_cert: Certificate Subject Name: /C=US/ST=California/L=San Jose/O=Cisco Systems/CN=AIR-CT5520-K9-a8b456ff51fb/[email protected]
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0799] dtls_verify_con_cert: Subject CN: AIR-CT5520-K9-a8b456ff51fb
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0799] dtls_connection_established: Connection established!
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0799] CAPWAP State: Join
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0899] Sending Join request to 172.29.22.12 through port 5248
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0899] local_in_addr_comp: Client and server addresses/port/version of 2 nodes are [172.29.22.158]:5248(65277)--[172.29.22.12]:5246(65277) [172.29.22.158]:5248--[172.29.22.12]:5246
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0899] dtls_connection_find_using_link_info: Searching connection [172.29.22.158]:5248--[172.29.22.12]:5246, result 0x2b4e2c00
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0899] dtls_cssl_msg_cb: Received >>> DTLS Header [Length 000d]
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0899] wtpDtlsCallback: DTLS-Ctrl Connection 0x2b4e2c00 established
May 11 08:13:19 kernel: [*05/11/2021 08:13:19.0899] dtls_process_packet: dtls connection established, reset harsa_retry_count
May 11 08:13:23 kernel: [*05/11/2021 08:13:23.7485] local_in_addr_comp: Client and server addresses/port/version of 2 nodes are [172.29.22.158]:5248(65277)--[172.29.22.12]:5246(65277) [172.29.22.158]:5248--[172.29.22.12]:5246
May 11 08:13:23 kernel: [*05/11/2021 08:13:23.7485] dtls_connection_find_using_link_info: Searching connection [172.29.22.158]:5248--[172.29.22.12]:5246, result 0x2b4e2c00
May 11 08:13:23 kernel: [*05/11/2021 08:13:23.7485] dtls_cssl_msg_cb: Received >>> DTLS Header [Length 000d]
May 11 08:14:16 kernel: [*05/11/2021 08:14:16.0622] local_in_addr_comp: Client and server addresses/port/version of 2 nodes are [172.29.22.158]:5248(65277)--[172.29.22.12]:5246(65277) [172.29.22.158]:5248--[172.29.22.12]:5246
May 11 08:14:16 kernel: [*05/11/2021 08:14:16.0622] dtls_connection_find_using_link_info: Searching connection [172.29.22.158]:5248--[172.29.22.12]:5246, result 0x2b4e2c00
May 11 08:14:16 kernel: [*05/11/2021 08:14:16.0622] wtpCloseAllDtlsConnections: Closing DTLS-CTRL connection 0x2b4e2c00.
May 11 08:14:16 kernel: [*05/11/2021 08:14:16.0622] dtls_cssl_msg_cb: Received >>> DTLS Header [Length 000d]
May 11 08:14:16 kernel: [*05/11/2021 08:14:16.0622] dtls_cssl_msg_cb: Received >>> DTLS 1.2 Alert [Length 0002] Warning Close notify
May 11 08:14:16 kernel: [*05/11/2021 08:14:16.0622] wtpDtlsCallback: DTLS-Ctrl Connection 0x2b4e2c00 closed
May 11 08:14:16 kernel: [*05/11/2021 08:14:16.0622] dtls_free_connection: Free done... for connection 0x2b4e2c00
May 11 08:14:16 kernel: [*05/11/2021 08:14:16.0622] dtls_connectionDB_del_connection: Deleted Connection 0x2b4e2c00, Server [172.29.22.12]:5246, Client [172.29.22.158]:5248, Count 0, rc_return 2
May 11 08:14:16 kernel: [*05/11/2021 08:14:16.0622] dtls_connection_find_using_link_info: Searching connection [172.29.22.158]:5248--[172.29.22.12]:5247, result (nil)
May 11 08:14:16 kernel: [*05/11/2021 08:14:16.0622] CAPWAP State: DTLS Teardown
May 11 08:14:16 upgrade: Script called with args:[ABORT]
May 11 08:14:16 kernel: [*05/11/2021 08:14:16.1921] upgrade.sh: Script called with args:[ABORT]
May 11 08:14:16 kernel: [*05/11/2021 08:14:16.2321] do ABORT, part1 is active part
May 11 08:14:16 upgrade: Cleanup tmp files ...
May 11 08:14:16 kernel: [*05/11/2021 08:14:16.2521] upgrade.sh: Cleanup tmp files ...
May 11 08:14:16 kernel: [*05/11/2021 08:14:16.2821] dtls_connection_find_using_link_info: Searching connection [172.29.22.158]:5248--[172.29.22.12]:5246, result (nil)
May 11 08:14:16 kernel: [*05/11/2021 08:14:16.2821] Dropping dtls packet since session is not established. Peer 172.29.22.12-5246, Local 172.29.22.158-5248, conn (nil)
May 11 08:14:16 kernel: [*05/11/2021 08:14:16.2821] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: DTLS Teardown(4).
May 11 08:14:30 kernel: [*05/11/2021 08:14:30.8076]
May 11 08:14:30 kernel: [*05/11/2021 08:14:30.8076] CAPWAP State: Discovery
May 11 08:14:30 kernel: [*05/11/2021 08:14:30.8076] Discovery Request sent to 172.29.22.12, discovery type STATIC_CONFIG(1)
May 11 08:14:30 kernel: [*05/11/2021 08:14:30.8176] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
May 11 08:14:30 kernel: [*05/11/2021 08:14:30.8276] Discovery Response from 172.29.22.12
May 11 08:14:30 kernel: [*05/11/2021 08:14:30.9475] systemd[1]: Starting dhcpv6 client watcher...
May 11 08:14:30 kernel: [*05/11/2021 08:14:30.9675] systemd[1]: Stopping DHCPv6 client...
May 11 08:14:31 kernel: [*05/11/2021 08:14:31.0375] systemd[1]: Starting DHCPv6 client...
May 11 08:14:31 kernel: [*05/11/2021 08:14:31.1574] systemd[1]: Started DHCPv6 client.
May 11 08:14:31 kernel: [*05/11/2021 08:14:31.2974] systemd[1]: Started dhcpv6 client watcher.
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0000]
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0000] CAPWAP State: DTLS Setup
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0000] dtls_cssl_msg_cb: Received >>> DTLS Header [Length 000d]
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0000] dtls_cssl_msg_cb: Received >>> DTLS 1.2 Handshake [Length 00ac] ClientHello
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0000] dtls_connectionDB_add_connection: Added Connection 0x2b4e2c00 Server [172.29.22.12]:5246 Client [172.29.22.158]:5248
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0000] create_dtls_connection: Creating DTLS Ctrl Connection 0x2b4e2c00
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0000] local_in_addr_comp: Client and server addresses/port/version of 2 nodes are [172.29.22.158]:5248(0)--[172.29.22.12]:5246(0) [172.29.22.158]:5248--[172.29.22.12]:5246
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0000] dtls_connection_find_using_link_info: Searching connection [172.29.22.158]:5248--[172.29.22.12]:5246, result 0x2b4e2c00
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0000] dtls_cssl_msg_cb: Sent <<< DTLS Header [Length 000d]
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0000] dtls_cssl_msg_cb: Sent <<< DTLS 1.2 Handshake [Length 002f] HelloVerifyRequest
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0000] dtls_cssl_msg_cb: Received >>> DTLS 1.2 Handshake [Length 00cc] ClientHello
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0000] dtls_process_packet: SSL get error rc 5
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0000] dtls_cssl_msg_cb: Sent <<< DTLS 1.2 Handshake [Length 005e] ServerHello
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0000] dtls_cssl_msg_cb: Sent <<< DTLS 1.2 Handshake [Length 048a] Certificate
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0000] dtls_cssl_msg_cb: Sent <<< DTLS 1.2 Handshake [Length 0067] CertificateRequest
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0000] dtls_cssl_msg_cb: Sent <<< DTLS 1.2 Handshake [Length 000c] ServerHelloDone
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0000] dtls_cssl_msg_cb: Received >>> DTLS 1.2 Handshake [Length 0485] Certificate
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0000] dtls_cssl_msg_cb: Received >>> DTLS 1.2 Handshake [Length 010e] ClientKeyExchange
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0199] dtls_cssl_msg_cb: Received >>> DTLS Header [Length 000d]
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0199] dtls_cssl_msg_cb: Received >>> DTLS 1.2 Handshake [Length 0110] CertificateVerify
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0199] dtls_cssl_msg_cb: Received >>> DTLS 1.2 ChangeCipherSpec [Length 0001]
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0299] dtls_cssl_msg_cb: Received >>> DTLS Header [Length 000d]
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0299] dtls_cssl_msg_cb: Received >>> DTLS 1.2 Handshake [Length 0018] Finished
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0299] dtls_process_packet: SSL get error rc 5
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0399] local_in_addr_comp: Client and server addresses/port/version of 2 nodes are [172.29.22.158]:5248(65277)--[172.29.22.12]:5246(65277) [172.29.22.158]:5248--[172.29.22.12]:5246
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0399] dtls_connection_find_using_link_info: Searching connection [172.29.22.158]:5248--[172.29.22.12]:5246, result 0x2b4e2c00
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0399] dtls_cssl_msg_cb: Sent <<< DTLS Header [Length 000d]
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0399] dtls_cssl_msg_cb: Sent <<< DTLS 1.2 ChangeCipherSpec [Length 0001]
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.0399] dtls_cssl_msg_cb: Sent <<< DTLS 1.2 Handshake [Length 0018] Finished
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.1399] dtls_load_ca_certs: LSC not enabled
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.1399] dtls_verify_con_cert: serverAuth not set in Controller certificate!
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.1399] dtls_verify_con_cert: Certificate Subject Name: /C=US/ST=California/L=San Jose/O=Cisco Systems/CN=AIR-CT5520-K9-a8b456ff51fb/[email protected]
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.1399] dtls_verify_con_cert: Subject CN: AIR-CT5520-K9-a8b456ff51fb
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.1599] dtls_connection_established: Connection established!
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.1599] CAPWAP State: Join
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.1599] Sending Join request to 172.29.22.12 through port 5248
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.1599] local_in_addr_comp: Client and server addresses/port/version of 2 nodes are [172.29.22.158]:5248(65277)--[172.29.22.12]:5246(65277) [172.29.22.158]:5248--[172.29.22.12]:5246
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.1599] dtls_connection_find_using_link_info: Searching connection [172.29.22.158]:5248--[172.29.22.12]:5246, result 0x2b4e2c00
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.1599] dtls_cssl_msg_cb: Received >>> DTLS Header [Length 000d]
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.1599] wtpDtlsCallback: DTLS-Ctrl Connection 0x2b4e2c00 established
May 11 08:14:41 kernel: [*05/11/2021 08:14:41.1599] dtls_process_packet: dtls connection established, reset harsa_retry_count
May 11 08:14:45 kernel: [*05/11/2021 08:14:45.7485] local_in_addr_comp: Client and server addresses/port/version of 2 nodes are [172.29.22.158]:5248(65277)--[172.29.22.12]:5246(65277) [172.29.22.158]:5248--[172.29.22.12]:5246
May 11 08:14:45 kernel: [*05/11/2021 08:14:45.7485] dtls_connection_find_using_link_info: Searching connection [172.29.22.158]:5248--[172.29.22.12]:5246, result 0x2b4e2c00
May 11 08:14:45 kernel: [*05/11/2021 08:14:45.7485] dtls_cssl_msg_cb: Received >>> DTLS Header [Length 000d]
May 11 08:15:38 kernel: [*05/11/2021 08:15:38.0522] local_in_addr_comp: Client and server addresses/port/version of 2 nodes are [172.29.22.158]:5248(65277)--[172.29.22.12]:5246(65277) [172.29.22.158]:5248--[172.29.22.12]:5246
May 11 08:15:38 kernel: [*05/11/2021 08:15:38.0522] dtls_connection_find_using_link_info: Searching connection [172.29.22.158]:5248--[172.29.22.12]:5246, result 0x2b4e2c00
May 11 08:15:38 kernel: [*05/11/2021 08:15:38.0522] wtpCloseAllDtlsConnections: Closing DTLS-CTRL connection 0x2b4e2c00.
May 11 08:15:38 kernel: [*05/11/2021 08:15:38.0522] dtls_cssl_msg_cb: Received >>> DTLS Header [Length 000d]
May 11 08:15:38 kernel: [*05/11/2021 08:15:38.0522] dtls_cssl_msg_cb: Received >>> DTLS 1.2 Alert [Length 0002] Warning Close notify
May 11 08:15:38 kernel: [*05/11/2021 08:15:38.0522] wtpDtlsCallback: DTLS-Ctrl Connection 0x2b4e2c00 closed
May 11 08:15:38 kernel: [*05/11/2021 08:15:38.0522] dtls_free_connection: Free done... for connection 0x2b4e2c00
May 11 08:15:38 kernel: [*05/11/2021 08:15:38.0622] dtls_connectionDB_del_connection: Deleted Connection 0x2b4e2c00, Server [172.29.22.12]:5246, Client [172.29.22.158]:5248, Count 0, rc_return 2
May 11 08:15:38 kernel: [*05/11/2021 08:15:38.0622] dtls_connection_find_using_link_info: Searching connection [172.29.22.158]:5248--[172.29.22.12]:5247, result (nil)
May 11 08:15:38 kernel: [*05/11/2021 08:15:38.0622] CAPWAP State: DTLS Teardown
May 11 08:15:38 upgrade: Script called with args:[ABORT]
May 11 08:15:38 kernel: [*05/11/2021 08:15:38.1921] upgrade.sh: Script called with args:[ABORT]
May 11 08:15:38 kernel: [*05/11/2021 08:15:38.2321] do ABORT, part1 is active part
May 11 08:15:38 upgrade: Cleanup tmp files ...
May 11 08:15:38 kernel: [*05/11/2021 08:15:38.2521] upgrade.sh: Cleanup tmp files ...
May 11 08:15:38 kernel: [*05/11/2021 08:15:38.2821] dtls_connection_find_using_link_info: Searching connection [172.29.22.158]:5248--[172.29.22.12]:5246, result (nil)
May 11 08:15:38 kernel: [*05/11/2021 08:15:38.2821] Dropping dtls packet since session is not established. Peer 172.29.22.12-5246, Local 172.29.22.158-5248, conn (nil)
May 11 08:15:38 kernel: [*05/11/2021 08:15:38.2821] Discarding msg CAPWAP_WTP_EVENT_REQUEST(type 9) in CAPWAP state: DTLS Teardown(4).
2 Accepted Solutions
saravlak
what's wlc code version, does it run AP supported version.
are correct country code enabled in wlc.
are time correct on wlc.
are license enabled in WLC and EULA accepted.
evaluation license has expired.
I added a license and fixed the issue.
Have a nice day.
Mark Elsen
 - You are not including ap-model , neither controller-model , for compatibility info's go here :
                           https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
saravlak
Have a nice day.
Leo Laohoo
Post the complete output to the following commands:
  1. WLC:  sh sysinfo
  2. WLC:  sh time
  3. WLC:  sh ap join detain <AP MAC ADDRESS>
  4. AP:  sh version
