12-03-2018 01:56 PM - edited 07-05-2021 09:32 AM
hi all
i have problem with my AP . im using linsys wap300n connecting to cisco switch 2960 POE 24 port
the internet connection always dropped also AP not forwarding the traffic so i cant also access local resources or ping to any device
the issue getting solved by resetting the device and reconfigure again with changing the switch port but after matter of time the issue comes back again
so the problem is from the brand of the AP and if i use one from the following AP brands my problem gonna be fixed and internet connection will be stable ?
what do u recommend for me ?
my company users number around 40 and less than
12-06-2018 12:25 AM
12-08-2018 03:12 PM - edited 12-08-2018 03:23 PM
thanks for the advice and its very helpful , can i ask u to help me for selecting a good and heavy duty AP for my office ?
which AIRONET AP should i buy with suitable price and not too much expensive but also high quality and rarely becomes down like AP that i used i always restart or reset and reconfigure the device for fixing the dropping network traffic for some time and back again to same issue
i have another issue ?? should i have to use these APs with WLC ? becuase i need only AP working alone ?
aironet 1815-1830-1850 ???should need WLC for working ? also 3800 and 2800??
thanks a lot
12-09-2018 01:37 AM
i have quotation price for 1832 and 1815 ? can u please check the price ? and which one is better to go with ?
should i use WLC device to operate these APs? i dont like to use WLC for now so the AP will work normally correct ?
whats the difference between AIR-AP1832I-I-K9C and AIR-AP1832I-I-K9 ? ihave 2 quote one with c and one without ? so whats the difference and which one is better ?
12-09-2018 08:39 AM
