ap elevator solution
Can you explain me some technics of ap installing in elevator for skyscrapers
do you install ap on every floor, or you installing it in elevator mine
also if cisco has ap for internal installation with two antennas
please give me some explanation
Scott Fella
Well in the states, many cities don't allow these equipment in the elevator shaft. I think the best solution is if the elevator company can run an Ethernet cable in the shaft (depending on length) and place an AP inside the car. I have seen APs mounted outside the elevator doors and depending on the door, your signal can be lost when the door closes. You also have to look at the roaming from switching access points, which can cause an unreliable solution.
Other options is running a DAS in the elevator shaft. Speak with the elevator company to see what suggestions they have.
-Scott
