wireless mesh
Hello
we have two access point, one of them will work in two mode 2.4 and 5
5 for connection between this access points through the wireless mesh, and 2.4 internet for clients in elevator cab, mesh between this two ap on 5 ghz is like a bridge between them to provide internet connection
so the question is will it work? and if yes please provide some documentation for this type of design
thank you
George Stefanick
Are you attempting to provide voice coverage in the cab ? Your thinking is correct. You will need to place aps outside the elevator in mesh rap mode.
No just for internet data
Scott Fella
I guess the question is, where will the RAP be located? With mesh, you have to keep a good signal or else the mesh backhaul connection will drop.
-Scott
