AP fails to join controller WLC
juliangriba
I am not able to get the AP's to join the WLC, Here is the WLC sysinfo and AP SH version info, and the boot up process for both APs as well. Thank you.
Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.3.122.0
RTOS Version..................................... 8.3.122.0
Bootloader Version............................... 8.2.151.0
Emergency Image Version.......................... 8.2.151.0
OUI File Update Time............................. Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... TSLAB
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.2170
Redundancy Mode.................................. Disabled
IP Address....................................... 192.168.2.2
IPv6 Address..................................... ::
System Up Time................................... 0 days 4 hrs 14 mins 0 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
--More-- or (q)uit
System Stats Normal Interval..................... 180
Configured Country............................... US  - United States
Operating Environment............................ Commercial (10 to 35 C)
Internal Temp Alarm Limits....................... 10 to 38 C
Internal Temperature............................. +22 C
Fan Status....................................... OK
State of 802.11b Network......................... Disabled
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
OUI Classification Failure Count................. 0
Burned-in MAC Address............................ 38:0E:4D:0B:A0:CB
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 1500
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1/SHA2
Licensing Type................................... RTU
P00f2.8b59.ff10>sh version
Cisco IOS Software, C1570 Software (C1570-K9W8-M), Version 15.3(3)JD6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Fri 04-Aug-17 01:28 by prod_rel_team
ROM: Bootstrap program is C1570 boot loader
BOOTLDR: C1570 Boot Loader (C1570-BOOT-M) LoaderVersion 15.3() [ TRUE]
AP00f2.8b59.ff10 uptime is 4 minutes
System image file is "flash:/c1570-k9w8-mx.153-3.JD6/c1570-k9w8-mx.153-3.JD6"
Last reload reason:
 avr reset reason: 0x96 LO Voltage RESET
 avr last power source: 0x1 High Power (60W) POE
 avr MCUSR reg : 0x5 Brown-out Reset
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-AP1572EAC-B-K9   (PowerPC) processor (revision D0) with 376814K/134656K bytes of memory.
Processor board ID FJC2005J03K
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.3.122.0
5 Gigabit Ethernet interfaces
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:F2:8B:59:FF:10
Part Number                          : 73-15697-05
PCB Serial Number                    : FOC19487A14
Top Assembly Part Number             : 068-05342-01
Top Assembly Serial Number           : FJC2005J03K
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1572EAC-B-K9
Configuration register is 0xF
Bootloader
OS Bootloader - Starting system.
flash is writable
40MB format
Cyprus MB -- 40MB of flash
Xmodem file system is available.
flashfs[0]: 23 files, 5 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 13367296
flashfs[0]: Bytes available: 27791360
flashfs[0]: flashfs fsck took 10 seconds.
Base Ethernet MAC address: 00:f2:8b:59:ff:10
 port 5 Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/c1570-k9w8-mx.153-3.JD6/c1570-k9w8-mx.153-3.JD6"...#############################################
File "flash:/c1570-k9w8-mx.153-3.JD6/c1570-k9w8-mx.153-3.JD6" uncompressed and installed, entry point: 0x1003000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
40MB format
Initializing flashfs...
flashfs[2]: 23 files, 5 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 40900608
flashfs[2]: Bytes used: 13367296
flashfs[2]: Bytes available: 27533312
flashfs[2]: flashfs fsck took 12 seconds.
flashfs[2]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 0 seconds.
flashfs[4]: Initialization complete.
Copying radio files from flash: to ram:
Copy in progress...CCC
Copy in progress...CCCCCCCCCCC
Uncompressing radio files...
...done Initializing flashfs.
 create idb =65A47C4
 vtu index 1 is created
 vtu index 2 is created
 vtu index 3 is created
 vtu index 4 is created
 vtu index 5 is created
 eth_wait stop the ios now, need be changed to 0
Radio0  present 8764 8000 0 A8000000 A8010000 0
Rate table has 650 entries (20 legacy/224 11n/406 11ac)
POWER TABLE FILENAME = ram:/P2.bin
Radio1  present 8864 8000 0 80000000 80100000 4
POWER TABLE FILENAME = ram:/P5.bin
export@cisco.com.
2 802.11 Radios
% Please define a domain-name first.
 fake phy int done idb =65A47C4
Press RETURN to get started!
*Mar  1 00:00:15.847: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15)
*Mar  1 00:00:16.311: Registering HW DTLS
*Mar  1 00:00:16.315: Non-Cable-Modem AP present
*Mar  1 00:00:17.191:  idb 0 =99AFB2C
*Mar  1 00:00:17.191:  idb 1 =99B1300
*Mar  1 00:00:17.191:  idb 2 =99B2EA8
*Mar  1 00:00:17.191:  idb 3 =99B4A9C
*Mar  1 00:00:17.191:  idb 4 =99B6690
*Mar  1 00:00:19.735: %LINK-6-UPDOWN: Interface Ethernet0, changed state to up
*Mar  1 00:00:19.735: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:19.735: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed state to up
*Mar  1 00:00:19.735: %LINK-6-UPDOWN: Interface GigabitEthernet2, changed state to up
*Mar  1 00:00:19.735: %LINK-6-UPDOWN: Interface GigabitEthernet3, changed state to up
*Mar  1 00:00:19.735: %LINK-6-UPDOWN: Interface GigabitEthernet4, changed state to up
*Mar  1 00:00:20.735: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar  1 00:00:20.735: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1, changed state to down
*Mar  1 00:00:20.735: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2, changed state to down
*Mar  1 00:00:20.735: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet3, changed state to down
*Mar  1 00:00:20.735: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4, changed state to down
*Mar  1 00:00:22.239: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar  1 00:00:22.351: loading Power Tables from ram:/P2.bin. Class = A
*Mar  1 00:00:22.351:  record size of 3ss: 1168 read_ptr: 523DDBE
*Mar  1 00:00:27.531: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (4)
*Mar  1 00:00:27.575: loading Power Tables from ram:/P5.bin. Class = B
*Mar  1 00:00:27.579:  record size of vht: 2904 read_ptr: 523DDBE
*Mar  1 00:00:27.667: AP Mesh platform identified (backhaul config:0x2, access:0xF)
APAVC Registering AVC licences on the AP to make sure we enable advanced PP
*Mar  1 00:00:28.723: Starting Ethernet promiscuous modeAPAVC Protocol list already initialized.
*Mar  1 00:00:28.991: Start STILE Activation
APAVC: Succeeded to activate all the STILE protocols.
APAVC: Registering with CFT
*Mar  1 00:00:29.239: APAVC: CFT registration of delete callback succeeded
APAVC: Reattaching  Original Buffer pool for system use
*Oct  9 18:35:16.071: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to hostname change
*Oct  9 18:35:16.071: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to hostname change
*Oct  9 18:35:16.079: %SYS-5-RESTART: System restarted --
*Oct  9 18:35:16.083: %SNMP-5-COLDSTART: SNMP agent on host AP00f2.8b59.ff10 is undergoing a cold start
*Oct  9 18:35:16.191: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to configuration change
*Oct  9 18:35:16.191: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to configuration change
*Oct  9 18:35:17.123: The AVR image is up-to-date (1.0.0.31)
*Oct  9 18:35:17.127:  change led intensity to 100 percent
*Oct  9 18:35:17.127: AVR module accelerometer initialized
*Oct  9 18:35:17.147: %CDP_PD-4-POWER_OK: Full power - INJECTOR_DETECTED inline power source
*Oct  9 18:35:17.555: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Oct  9 18:35:17.559: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to hostname change
*Oct  9 18:35:17.559: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to hostname change
*Oct  9 18:35:17.563: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to configuration change
*Oct  9 18:35:17.563: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to configuration change
*Oct  9 18:35:18.283: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to interface reset
*Oct  9 18:35:18.483: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct  9 18:35:18.483: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to interface resetlwapp_crypto_init: MIC Present and Parsed Successfully
*Oct  9 18:35:18.651: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Oct  9 18:35:18.651: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Oct  9 18:35:19.339: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Oct  9 18:35:19.487: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Oct  9 18:35:19.655: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Oct  9 18:35:21.819: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1, changed state to down
*Oct  9 18:35:21.819: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2, changed state to down
*Oct  9 18:35:21.819: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet3, changed state to down
*Oct  9 18:35:21.819: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4, changed state to down
*Oct  9 18:35:22.019: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (2-16)
*Oct  9 18:35:22.019: DPAA Initialization Complete
*Oct  9 18:35:22.019: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Oct  9 18:35:28.191: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Oct  9 18:35:29.191: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*Oct  9 18:35:31.727: *Set ap_bg_vlan.pending_root_hwidb=GigabitEthernet1
*Oct  9 18:35:31.727: *Received a MON_IDB_MSG
*Oct  9 18:35:31.731: *Received a MON_IDB_MSG
*Oct  9 18:35:33.731: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*Oct  9 18:35:34.479: Currently running a Release Image
*Oct  9 18:35:34.499: Using SHA-2 signed certificate for image signing validation.
*Oct  9 18:35:34.727: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1, changed state to up
*Oct  9 18:35:34.731: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Oct  9 18:35:36.139: Orientation: Changed to Vertical%Default route without gateway, if not a point-to-point interface, may impact performance
*Oct  9 18:35:40.467: AP image integrity check PASSED
*Oct  9 18:35:40.475: Non-recovery image. PNP Not required.
*Oct  9 18:35:40.535: Cert ISSUER (39): cn=Cisco Manufacturing CA SHA2,o=Cisco
*Oct  9 18:35:41.555: %DOT11-4-DIVER2_USED: Interface Dot11Radio0, Mcs rates 16-23 disabled due to only two transmit or receive antennas enabled
*Oct  9 18:35:41.659: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Oct  9 18:35:42.651: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Oct  9 18:35:42.663: %DOT11-4-DIVER2_USED: Interface Dot11Radio1, Mcs rates 16-23 disabled due to only two transmit or receive antennas enabled
*Oct  9 18:35:42.883: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Oct  9 18:35:42.891: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Oct  9 18:35:42.899: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Oct  9 18:35:43.883: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Oct  9 18:35:43.891: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Oct  9 18:35:43.927: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct  9 18:35:44.547: %MESH-6-ADJACENCY_STATE_MACHINE_STARTED: Mesh adjacency state machine started
*Oct  9 18:35:44.927: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
%Error opening flash:/capwap-saved-config (No such file or directory)
%Error opening flash:/capwap-saved-config-bak (No such file or directory)
*Oct  9 18:35:50.567: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 0 CLI Request Triggered
*Oct  9 18:35:51.567: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 514 started - CLI initiated
Not in Bound state.
*Oct  9 18:36:52.607: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Oct  9 18:36:58.671: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to hostname change
*Oct  9 18:36:58.671: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to hostname change
*Oct  9 18:36:58.671: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to configuration change
*Oct  9 18:36:58.671: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to configuration change
*Oct  9 18:36:58.679: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Oct  9 18:36:58.695: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Oct  9 18:36:59.679: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Oct  9 18:36:59.715: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Oct  9 18:36:59.723: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Oct  9 18:36:59.731: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Oct  9 18:37:00.715: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Oct  9 18:37:00.723: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Oct  9 18:37:00.759: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Oct  9 18:37:01.759: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Oct  9 18:39:22.607: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Oct  9 18:39:22.607: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Oct  9 18:39:22.607: %MESH-6-LINK_UPDOWN: Mesh station 00f2.8b59.ff11 link Down
Not in Bound state.
*Oct  9 18:40:33.783: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Oct  9 18:40:39.847: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to hostname change
*Oct  9 18:40:39.847: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to hostname change
*Oct  9 18:40:39.847: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to configuration change
*Oct  9 18:40:39.847: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to configuration change
*Oct  9 18:40:39.863: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
Second AP
Mar  1 01:02:14.375: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-startedÿ
IOS Bootloader - Starting system.
flash is writable
40MB format
flashfs[0]: 22 files, 5 directories
flashfs[0]: Bytes used: 13239296
flashfs[0]: Bytes available: 27919360
Base Ethernet MAC address: 38:90:a5:c6:e6:c0
executing...
           cisco Systems, Inc.
40MB format
flashfs[2]: 22 files, 5 directories
flashfs[2]: Bytes used: 13239296
flashfs[2]: Bytes available: 27661312
 create idb =667BAE4
export@cisco.com.
cisco AIR-AP1572EAC-B-K9   (PowerPC) processor (revision E1) with 376814K/134656K bytes of memory.
Processor board ID FJC2135J00W
2 802.11 Radios
Base ethernet MAC Address: 38:90:A5:C6:E6:C0
PCB Serial Number                    : FOC213017PN
Top Assembly Part Number             : 068-05342-02
Top Assembly Serial Number           : FJC2135J00W
 fake phy int done idb =667BAE4
*Mar  1 00:00:15.843: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15)
*Mar  1 00:00:16.307: Registering HW DTLS
*Mar  1 00:00:17.183:  idb 0 =9A86E4C
*Mar  1 00:00:17.187:  idb 1 =9A88868
*Mar  1 00:00:17.187:  idb 2 =9A8A410
*Mar  1 00:00:17.187:  idb 3 =9A8C004
*Mar  1 00:00:17.187:  idb 4 =9A8DBF8
*Mar  1 00:00:19.731: %LINK-6-UPDOWN: Interface Ethernet0, changed state to up
*Mar  1 00:00:19.731: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:19.731: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed state to up
*Mar  1 00:00:19.731: %LINK-6-UPDOWN: Interface GigabitEthernet2, changed state to up
*Mar  1 00:00:19.731: %LINK-6-UPDOWN: Interface GigabitEthernet3, changed state to up
*Mar  1 00:00:19.731: %LINK-6-UPDOWN: Interface GigabitEthernet4, changed state to up
*Mar  1 00:00:20.731: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar  1 00:00:20.731: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1, changed state to down
*Mar  1 00:00:20.731: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2, changed state to down
*Mar  1 00:00:20.731: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet3, changed state to down
*Mar  1 00:00:20.731: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4, changed state to down
*Mar  1 00:00:22.227: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0 (4)
*Mar  1 00:00:22.343: loading Power Tables from ram:/P2.bin. Class = A
*Mar  1 00:00:22.343:  record size of 3ss: 1168 read_ptr: 5315536
*Mar  1 00:00:27.519: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1 (4)
*Mar  1 00:00:27.567: loading Power Tables from ram:/P5.bin. Class = B
*Mar  1 00:00:27.567:  record size of vht: 2904 read_ptr: 5315536
*Mar  1 00:00:27.655: AP Mesh platform identified (backhaul config:0x2, access:0xF)
*Mar  1 00:00:28.987: Start STILE Activation
*Mar  1 00:00:29.235: APAVC: CFT registration of delete callback succeeded
*Mar  1 00:48:53.067: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to hostname change
*Mar  1 00:48:53.067: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to hostname change
*Mar  1 00:48:53.075: %SYS-5-RESTART: System restarted --
*Mar  1 00:48:53.075: %SNMP-5-COLDSTART: SNMP agent on host TSLABMAP is undergoing a cold start
*Mar  1 00:48:53.179: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to configuration change
*Mar  1 00:48:53.179: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to configuration change
*Mar  1 00:48:53.267: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to hostname change
*Mar  1 00:48:53.267: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to hostname change
*Mar  1 00:48:53.795: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to configuration change
*Mar  1 00:48:53.827: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to interface reset
*Mar  1 00:48:53.831: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:48:53.843: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to interface resetlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:48:54.015: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:48:54.015: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:48:54.119: The AVR image is up-to-date (1.0.0.31)
*Mar  1 00:48:54.123:  change led intensity to 100 percent
*Mar  1 00:48:54.123: AVR module accelerometer initialized
*Mar  1 00:48:54.155: %CDP_PD-4-POWER_OK: Full power - INJECTOR_DETECTED inline power source
*Mar  1 00:48:54.547: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:48:55.255: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:48:55.255: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:48:56.263: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to down
*Mar  1 00:48:57.143: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1, changed state to down
*Mar  1 00:48:57.143: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet2, changed state to down
*Mar  1 00:48:57.143: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet3, changed state to down
*Mar  1 00:48:57.143: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet4, changed state to down
*Mar  1 00:49:01.559: %SOAP_FIPS-2-SELF_TEST_HW_SUCCESS: HW crypto FIPS self test passed (2-16)
*Mar  1 00:49:01.559: DPAA Initialization Complete
*Mar  1 00:49:01.559: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar  1 00:49:05.179: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar  1 00:49:06.179: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
*Mar  1 00:49:08.719: *Set ap_bg_vlan.pending_root_hwidb=GigabitEthernet1
*Mar  1 00:49:08.719: *Received a MON_IDB_MSG
*Mar  1 00:49:08.731: *Received a MON_IDB_MSG
*Mar  1 00:49:10.731: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*Mar  1 00:49:11.471: Currently running a Release Image
*Mar  1 00:49:11.491: Using SHA-2 signed certificate for image signing validation.
*Mar  1 00:49:11.719: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet1, changed state to up
*Mar  1 00:49:11.731: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar  1 00:49:13.131: Orientation: Changed to Vertical%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar  1 00:49:17.459: AP image integrity check PASSED
*Mar  1 00:49:17.467: Non-recovery image. PNP Not required.
*Mar  1 00:49:17.527: Cert ISSUER (39): cn=Cisco Manufacturing CA SHA2,o=Cisco
*Mar  1 00:49:18.547: %DOT11-4-DIVER2_USED: Interface Dot11Radio0, Mcs rates 16-23 disabled due to only two transmit or receive antennas enabled
*Mar  1 00:49:18.655: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:49:19.647: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:49:19.659: %DOT11-4-DIVER2_USED: Interface Dot11Radio1, Mcs rates 16-23 disabled due to only two transmit or receive antennas enabled
*Mar  1 00:49:19.879: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:49:19.887: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Mar  1 00:49:19.895: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:49:20.879: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:49:20.887: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:49:20.923: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:49:21.539: %MESH-6-ADJACENCY_STATE_MACHINE_STARTED: Mesh adjacency state machine started
*Mar  1 00:49:21.923: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:49:27.563: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 0 CLI Request Triggered
*Mar  1 00:49:28.563: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host 255.255.255.255 port 514 started - CLI initiated
Not in Bound state.
*Mar  1 00:50:39.987: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:50:45.059: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to hostname change
*Mar  1 00:50:45.059: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to hostname change
*Mar  1 00:50:45.059: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to configuration change
*Mar  1 00:50:45.059: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to configuration change
*Mar  1 00:50:45.075: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Mar  1 00:50:45.079: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:50:46.079: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:50:46.099: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:50:46.107: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Mar  1 00:50:46.115: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:50:47.099: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:50:47.107: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Mar  1 00:50:47.143: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Mar  1 00:50:48.143: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Mar  1 00:53:09.987: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join timer expired
*Mar  1 00:53:09.987: %MESH-3-TIMER_EXPIRED: Mesh Lwapp join failed expired
*Mar  1 00:53:09.987: %MESH-6-LINK_UPDOWN: Mesh station 3890.a5c6.e6c1 link Down
Not in Bound state.
*Mar  1 00:54:31.419: %MESH-6-CAPWAP_RESTART: Mesh Capwap re-started
*Mar  1 00:54:36.487: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to hostname change
*Mar  1 00:54:36.487: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to hostname change
*Mar  1 00:54:36.487: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to configuration change
*Mar  1 00:54:36.487: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to configuration change
*Mar  1 00:54:36.491: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Mar  1 00:54:36.507: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Mar  1 00:54:37.491: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Mar  1 00:54:37.527: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Mar  1 00:54:37.535: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Mar  1 00:54:37.543: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Mar  1 00:54:38.527: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Mar  1 00:54:38.535: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
I don't see that AP is getting an IP address in the boot process. Can you verify that DHCP is working fine? Or you can try a static IP.
10 Replies 10
juliangriba
Already added MAC address to MAC filtering, issue remains.
Did you add the mac address at Security>AAA>AP Policies ?
Already Added MAC addresses, to MAC filtering and under AAA policies MIC is enable, issue remains.
coolbreeze
Hello!
Are these APs trying to join to the WLC for the first time, or have they joined previously at any point?
Do your APs usually autodiscover the WLC or do you manually configure the primary controller, etc.?
Are they being added to an existing mesh configuration or net new?  Have they already been set up with config of some kind?
Could you provide a simple logical diagram of how the APs are connecting or how the network is arranged in regards to the APs?
CoolBreeze
Is this AP trying to connect as a mesh AP? Please turn on the radios at the global level of WLC. It seems radios are turned off according to output posted. Also make sure there are root mesh APs around to connect.
Other things to check.
  • System time of the WLC
  • Sufficient license count.
  • Connectivity from AP subnet to WLC
Time Checked, License count checked 1500 only using two AP for now.
Leo Laohoo
Upgrade the firmware of the controller first.
WLC was previously working with same FW version, I defaulted WLC  for demonstration purposes now AP's are not able to join.
DHCP Issue, thanks
