AP For concurrent 70 users
saroj pradhan
Level 4
Level 4
can  any one  please  help  me  i want  a AP  which  can  support  concurrent  70 users or more  .
Also  support MAC Address filter  can add atleast  100 MAC on the AP.
Saroj
11 Replies 11
Leo Laohoo
In theory?  ALL WAPs can THEORETICALLY support 2048 clients.
PRACTICALLY?  Depending on your traffic.  If your wifi traffic is, say surfing the internet, emails, FB, chat, then 35 clients to a WAP is a good number.
If you are pushing time-critical application, like video, then the number drops down to 8.
my users  perform  RDP ,Skype and  other  works  link LAN CABLE Connection.
please advice some  AP Series  i can use.
Scott Fella
Just to add to Leo's post
Q. Is there a limitation on the number of MAC address filters that can be configured on the AP?
A. You can use the CLI in order to configure up to 2,048 MAC addresses for filtering, but, with the use of the web-browser interface, you can configure only up to 43 MAC addresses for filtering.
-Scott
i have  a cisco AP 4410N Series  in my network which  support 20 MAC add through web interface.
can i add more users through CLI ? If yes  plesae advice me the steps to do .
I don't know about that model ap On the enterprise APs like the 1142, 1252, 1262 you can from the CLI.
-Scott
plaese find the cli  access and  the options  in my ap 4410n.
get beaconinterval                 -- Display Beacon Interval,(Range:20 ~ 1000)
get channel                        -- Display Radio Channel
get country                        -- Display Country/Domain
get ethdatarate                    -- Display Ethernet Data Rate
get ethAutoNegotiation             -- Display Ethernet Negotiation Mode
get ethDuplexMode                  -- Display Ethernet Duplex Mode
get ctsprotect                     -- Display CTS Protect Mode
get defaultkey                     -- Display Default Key Index
get devicename                     -- Display Access Point Dvice Name
get dhcp                           -- Display DHCP Mode
get dns2server                     -- Display IP Address of Secondary DNS Server
get dnsserver                      -- Display IP Address of DNS Server
get dot1xdynkeylife                -- Display 802.1x Dynamic Key Life Time (in Seconds)
get dtiminterval                   -- Display DTIM interval,(Range:1 ~ 255)
get emailaddress                   -- Display Email Address for Log
get emailalert                     -- Display Email Alert Mode
get emailinterval                  -- Display Email Time Threshold
get emailqueue                     -- Display Email Queue Length
get emailserver                    -- Display Email Alert Server
get encryption                     -- WPA encryption Algorithm(TKIP/AES)
get fragthreshold                  -- Display Fragment Threshold,(Default: 2346, Range: 256 ~ 2346)
get fwversion                      -- Display Firmware Version
get gateway                        -- Display Gateway IP Address
get hostname                       -- Display Access Point Host Name
get bonjour                        -- Display Bonjour Mode
get wps                            -- Display Wps Mode
get forcelan100m                   -- Display Force LAN Port Speed to 100M
get httpredirect                   -- Display HTTP Redirect Mode
get httpredirectURL                -- Display HTTP Redirect URL
get https                          -- Display HTTPS Mode
get pidvid                         -- Display PID VID
get ipaddr                         -- Display IP Address
get ipmask                         -- Display IP Subnet Mask
get ipv6                           -- Display IPv6 Mode
get ipv6addr                       -- Display IPv6 Local Address
get ipv6dns1                       -- Display IPv6 Primary DNS Server
get ipv6dns2                       -- Display IPv6 Secondary DNS Server
get ipv6gateway                    -- Display IPv6 Default Gateway
get isolationbetweenssid           -- Display Isolate All Virtual APs State
get isolationwithinssid            -- Display Isolation within VAP
get key                            -- Display WEP Key Value
get keylength                      -- Display WEP Key Length
get keyrenew                       -- Display Group Key Update Interval (in Seconds)
get lltd                           -- Display LLTD Mode
get loadbalance                    -- Display Load Balance Mode
get loadbalancessid                -- Display Load Balance SSID
get logconfchange                  -- Display Log Configuration Changes Mode
get logfail                        -- Display Log Authorized Login Mode
get logsuccess                     -- Display Log Unauthorized Login Attempt Mode
get logsyserror                    -- Display Log System Error Messages Mode
get mcastenhance                   -- Display Multicast Packets Enhancement Mode
get md5supplicant                  -- Display 802.1x MD5 Supplicant Mode
get md5suppname                    -- Display 802.1x Supplicant MD5 Name
get md5supppassword                -- Display 802.1x Supplicant MD5 Password
get md5supptype                    -- Display 802.1x MD5 Supplicant Type
get nativevlanid                   -- Display Native VLAN ID
get ntp                            -- Display NTP Mode
get ntpserver                      -- Display NTP Server IP Address
get operationmode                  -- Display Operation Mode
get password                       -- Display Login Password
get priority                       -- Display Priority
get psk                            -- Display Pre-shared Key
get radiusserver                   -- Display RADIUS Server IP Address
get radiusport                     -- Display RADIUS Port Number
get radiussecret                   -- Display RADIUS Shared Secret
get bridgemac                      -- Display WDS Bridge's Remote MAC Address List
get repeatermac                    -- Display WDS Repeater's Remote MAC Address
get remotessid                     -- Display UC/UR's Remote SSID
get remoteucr                      -- Display UC/UR's Remote MAC Address
get roguelegal                     -- Display Legal AP List of Legal AP
get roguetype                      -- Display Rogue AP Definition
get rtsthreshold                   -- Display RTS Threshold,(Default: 2347, Range: 1 ~ 2347)
get security                       -- Display Wireless Security Mode
get snmpcontact                    -- Display SNMP Contact
get snmpdevice                     -- Display SNMP Devic Name
get snmplocation                   -- Display SNMP Location
get snmpreadcommunity              -- Display SNMP Read Community
get snmptrapcommunity              -- Display SNMP Trap Community
get snmpwritecommunity             -- Display SNMP Write Community
get snmpmode                       -- Display SNMP Mode
get ssh                            -- Display SSH Mode
get ssid                           -- Display Service Set ID
get ssidbroadcast                  -- Display SSID Broadcast Mode
get syslog                         -- Display Syslog Mode
get syslogserver                   -- Display Unicast Syslog Server Address
get time                           -- Display Current System Time
get timemode                       -- Display Time Mode
get timezone                       -- Display Time Zone Setting
get daylight                       -- Display Automatically adjust clock for daylight saving changes
get uptime                         -- Display Access Point Up Time
get username                       -- Display Login User Name
get vlan                           -- Display VLAN Operational State
get vlandefault                    -- Display AP Default VLAN
get vlanid                         -- Display the VLAN ID
get vlanmanagement                 -- Display AP Management VLAN
get vlantag                        -- Display Vlan Tag Mode
get vlantagoverwds                 -- Display Vlan Tag Over WDS Mode
get wlanaccess                     -- Display Wireless Web Access Mode
get wirelessmode                   -- Display Wireless LAN Mode
get wmm                            -- Display WMM Mode
get wmmps                          -- Display WMM PowerSaving Mode
set 11nguardinterval               -- Set 11n Guard Interval Mode
set 11nchanbandwidth               -- Set 11n Channel Bandwidth
set 802_11d                        -- Set 802.11d Mode
set acl                            -- Set Access Control
set active                         -- Set Active (up) Mode
set authentication                 -- Set Authentication Type of WEP
set beaconinterval                 -- Set Beacon Interval
set bridgemac                      -- Set Bridge's Remote MAC Address List
set channel                        -- Set Radio Channel
set country                        -- Set Country/Domain
set ethdatarate                    -- Set Ethernet Data Rate
set ethAutoNegotiation             -- Set Ethernet Auto Negotiation Mode
set ethDuplexMode                  -- Set Ethernet Duplex Mode
set ctsprotect                     -- Set CTS Protect Mode
set daylight                       -- Set Automatically adjust clock for daylight saving changes
set defaultkey                     -- Set Default Key Index
set devicename                     -- Set Access Point Dvice Name
set dhcp                           -- Set DHCP Mode
set dns2server                     -- Set IP Address of Secondary DNS Server
set dnsserver                      -- Set DNS Server IP Address
set dot1xdynkeylife                -- Set 802.1x Dynamic Key Life Time (in Seconds)
set dtiminterval                   -- Set DTIM interval,(Range:1 ~ 255)
set emailaddress                   -- Set Email Address for Log
set emailalert                     -- Set Email Alert Mode
set emailinterval                  -- Set Email Time Threshold
set emailqueue                     -- Set Email Queue Length
set emailserver                    -- Set Email Alert Server
set encryption                     -- Set WPA encryption Algorithm(TKIP/AES)
set fragthreshold                  -- Set Fragment Threshold
set gateway                        -- Set Gateway IP Address
set hostname                       -- Set Access Point Host Name
set bonjour                        -- Set Bonjour Mode
set wps                            -- Set WPS Mode
set forcelan100m                   -- Set Force LAN Port Speed to 100M
set httpredirect                   -- Set HTTP Redirect Mode
set httpredirectURL                -- Set HTTP Redirect URL
set https                          -- Set HTTPS Enable/Disable
set ipaddr                         -- Set IP Address
set ipmask                         -- Set IP Subnet Mask
set ipv6                           -- Set IPv6 Mode
set ipv6addr                       -- Set IPv6 Local Address
set ipv6dns1                       -- Set IPv6 Primary DNS Server
set ipv6dns2                       -- Set IPv6 Secondary DNS Server
set ipv6gateway                    -- Set IPv6 Default Gateway
set isolationbetweenssid           -- Set Isolate All Virtual APs State
set isolationwithinssid            -- Set Isolation within VAP
set key                            -- Set WEP Key Value
set keylength                      -- Set WEP Key Length
set keyrenew                       -- Set Group Key Update Interval (in Seconds)
set lltd                           -- Set LLTD Mode
set loadbalance                    -- Set Load Balance Mode
set loadbalancessid                -- Set Load Balance SSID
set logconfchange                  -- Set Log Configuration Changes Mode
set logfail                        -- Set Log Authorized Login Mode
set logsuccess                     -- Set Log Unauthorized Login Attempt Mode
set logsyserror                    -- Set Log System Error Messages Mode
set mcastenhance                   -- Set Multicast Packets Enhancement Enable/Disable
set md5supplicant                  -- Set 802.1x MD5 Supplicant Mode
set md5suppname                    -- Set 802.1x Supplicant MD5 Name
set md5supppassword                -- Set 802.1x Supplicant MD5 Password
set md5supptype                    -- Set 802.1x MD5 Supplicant Type
set nativevlanid                   -- Set Native VLAN ID
set ntp                            -- Set NTP Mode
set ntpserver                      -- Set NTP Server IP Address
set operationmode                  -- Set operation Mode
set password                       -- Modify Login Password
set priority                       -- Set Priority
set psk                            -- Modify Pre-shared Key
set radiusserver                   -- Set RADIUS IP Address
set radiusport                     -- Set RADIUS Port Number
set radiussecret                   -- Set RADIUS Shared Secret
set remotessid                     -- Set UC/UR's Remote SSID
set remoteucr                      -- Set UC/UR's Remote MAC Address
set repeatermac                    -- Set Repeater's MAC Address
set roguelegal                     -- Add/Delete Legal AP MAC/OUI
set roguetype                      -- Set Rogue AP Definition
set rtsthreshold                   -- Set RTS/CTS Threshold
set security                       -- Set Wireless Security Mode
set shortpreamble                  -- Set Short Preamble
set snmpcontact                    -- Set SNMP Contact
set snmpdevice                     -- Set SNMP Devic Name
set snmplocation                   -- Set SNMP Location
set snmpreadcommunity              -- Set SNMP Read Community
set snmptrapcommunity              -- Set SNMP Trap Community
set snmpwritecommunity             -- Set SNMP Write Community
set snmpmode                       -- Set SNMP Mode
set ssh                            -- Set SSH Mode
set ssid                           -- Set Service Set ID
set ssidbroadcast                  -- Set SSID Broadcast Mode
set syslog                         -- Set Syslog Mode
set syslogserver                   -- Set Unicast Syslog Server Address
set time                           -- Set Current System Time
set timemode                       -- Set Time Mode
set timezone                       -- Set Time Zone Setting
set username                       -- Modify Login User Name
set vlan                           -- Set VLAN Operational State
set vlandefault                    -- Set AP Native VLAN
set vlanid                         -- Set VAP VLAN id
set vlanmanagement                 -- Set AP Management VLAN
set vlantag                        -- Set Vlan Tag Mode
set vlantagoverwds                 -- Set Vlan Tag Over WDS Mode
set wlanaccess                     -- Set Wireless Web Access Mode
set wirelessmode                   -- Set Wireless LAN Mode
set wmm                            -- Set WMM Mode
set wmmps                          -- Set WMM PowerSaving Mode
tftp                               -- Software upgrade/download via TFTP
factoryrestore                     -- Restore to Default Factory Settings
apply                              -- To make the changes take effect
exit                               -- Quit the Remove Console
Can you advice what kind of budget are we talking about here?  Scott and I are very familiar with the "enterprise" level of wireless access points while you could be looking for a SOHO-type WAP.
The budget  is max  $ 300 to $400.
Ok, then I believe you're looking at a SOHO-class wireless access point like Linksys.  Scott, George, Steve and I are very familiar with the enterprise-grade WAPs.
I believe the Cisco 4410n that you are using is classed as SMB-grade WAP but I am also not familiar with this model.
can any one help me  How the cisco AP 541N works ?
  among the Cisco 500 and  cisco 600 series  which is better ?
