AP functionality or performance difference between PoE and PoE+
Carter Zhu
Visitor
For example, AP 1852 E normally requires 20w power, however, it is currently working on the PoE power which up to 15.4w. How could the performance be degraded? Any measurement or way to check out. Thanks!
No, the maximum Tx power will not be affected.
Mark Elsen
 - Sometimes not all radios will get enabled or not all of the antennas will be used. This can usually be verified by watching the startup process of the ap and or issue show logging on the ap just after boot.
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Leo Laohoo
1800 is a low-end, low-cost model.  If powered only with PoE then the high-end data rates are disabled.
Carter Zhu
Visitor
Thank you both for the reply! It helps me understand more. I checked the cisco web, and found this: https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9100-access-points/215467-cisco-access-point-power-requirements-qu.html, just for your reference.
One more question, do you think this would lead to a lower singal strength in this case?
