AP group question
Starthorn
Level 3
Level 3
When Editing a AP group under the WLAN tab, I see Interface Name. I see a few things in the drop down menu. Could someone explain the purpose of this ?
Stephen Rodriguez
AP group vlan is so that you can define what interface a SSID will use, on a particular AP or group of AP.
So for example, you have 4 floors, and on each floor you want a separate VLAN, but the SAME SSID. You would create the four dynamic interfaces, then you go to AP Group VLAN config, and say SSID map to . You would create four groups, one for each floor, and each group has the respective mapping. Then on the AP, you define what group the AP belongs to.
HTH,
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
ok, so each interface name in the drop down list is a vlan. I assume when these interface names were created that they were assigned a VLAN.
So I could kind of look at it like the drop down list houses a list of VLAN names instead of a number?
Look at it this way.... AP Groups allow you to have one SSID (TEST) mapped to multiple vlans. The purpose is if you like to keep a subnet at a /24 but have 2000 + users, AP Groups allow you to place AP's that will have ssis TEST on a certain vlan.
For example:
Floor 1 SSID Test
Interface Vlan 11
Vlan 11
Floor 2 SSID Test
Interface Vlan 12
Vlan 12
Floor 2 SSID Test
Interface Vlan 13
Vlan 13
-Scott
