AP Group Question..
beijingfengjie123
Community Member
I created two AP group, group1 get ip is 192.168.0.X, group2 obtain IP is 192.168.1.X, and broadcasts the same SSID (TEST), the client can be normal to the SSID, now found a problem when the client first connects to the AP group1 inside, then move to the AP group2, because IP is 192.168.0.X, so no Internet access, the connection must be disconnected from the new SSID before they can obtain an IP 192.168.1.X and access to the Internet.
Is there any way to solve this problem.
Scott Fella
This is the normal function that the WLC performs for layer 3 roaming.  You may comsider this in your desing in order to understand if your requirements can be met or not. You can't disable this feature.  You can "break" riaming if you have two controllers and AP Group 0 is assigned to one controller and AP Group 1 on the other. You just don't use the same mobility group name.  So if there is any rosming between the controllers, the device will have to reconnect.  This is not a good practice however.
-Scott
-Scott
