Cisco 2602e External Patch Antenna
prasad.gsmc
Level 4
Level 4
What are available list of external patch Antennas combatible with Cisco 2602e apart from AIR-ANT2524V4C-R and AIR-ANT2544V4M-R.
is AIR-ANT1728 combatible with 2602e
regards
Prasad
Scott Fella
To be honest, if you plan on using both the 2.4 ghz and the 5 ghz, then you need any four lead dual band antenna. You can look at other manufacture like PCTel or TerraWave. If you plan on disabling the other radio, then you can go with a single band antenna, but Not a preferred way to do thing. Stick with a four lead dual band.
-Scott
Moin Ilyas
Level 8
Level 8
Though it's an old query, in case someone would find it useful.
External Antennas
The 2602E models are configured with up to four external dual-band dipole antennas, and two 2.4-GHz/5-GHz dual-band radios. The radios and antennas support frequency bands 2400–2500 MHz and 5150–5850 MHz through a common dual-band RF interface. Features of the external dual-band dipole antennas are:
  • Four RTNC antenna connectors on the top of the access point
  • Three TX and four RX antennas
These antennas are supported on the 2602E:
Antenna Part Number
Antenna Type
Antenna Gain 2 GHz / 5 GHz (dBi)
AIR-ANT2524DB-R
Dual-resonant black dipole
2/4
AIR-ANT2524DW-R
Dual-resonant white dipole
2/4
AIR-ANT2524DG-R
Dual-resonant gray dipole
2/4
AIR-ANT2524V4C-R
Dual-resonant, ceiling-mount omni (4-pack)
2/4
AIR-ANT2544V4M-R
Dual-resonant omni (4-pack)
4/4
AIR-ANT2566P4W-R
Dual-resonant Directional antenna (4-pack)
6/6
For more details:
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/2600/quick/guide/ap2600getstart.html#pgfId-59090
