AP GUI doesn't change values.
essicka
I have a Cisco AP AIR-CAP1532I-E-K9. I converted it from lightweight to standalone using ap1g3-k9w7-tar.153-3.JK11.
The AP has a static IP, I am connected through the console using putty.
To be able to connect to the GUI I used the commands "enable secret ..." and "ip http server".
I can connect to the GUI of the AP through the web browser, but I can't change the values. After the "Apply" command the original values are there.
The user has Read-Only permissions.
I am new to Cisco and don't know the CLI commands.
Can you advise me the command/commands in CLI so that I can change the values in GUI?
Thank you.
Esi
With Read-Only permission - you will not be able to make any configuration changes. You need Read/write user account to do that.
Refer: Configuring Username and Password Pairs from the following URL
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/15-3-3/configuration/guide/cg15-3-3/cg15-3-3-chap5-admin.html#43832
Config t
login local
username <name> privilege 15 password 7 <password>
Jagan Chowdam
/**Pls rate useful responses**/
Config t
login local
Jagan Chowdam
essicka
Thank you for the advice, but when I wanted to try to apply it my AP says it doesn't know the local parameter for the login command.
The username command is also unknown.
Here is the listing:
ap#conf t
Enter configuration commands, one per line. End with CNTL/Z.
ap(config)#login local
% Invalid input detected at '^' marker.
ap(config)#login ?
block-for Set quiet-mode active time period
delay Set delay between successive fail login
on-failure Set options for failed login attempt
on-success Set options for successful login attempt
quiet-mode Set quiet-mode options
ap(config)#login
ap#
*Mar 1 00:31:09.715: %SYS-5-CONFIG_I: Configured from console by console
ap#
*Mar 1 00:32:22.291: SGMII debug status:0x7
*Mar 1 00:32:22.319: SGMII auto correction -- success
ap#
ap#username XXX privilege 15 password 0 xxx
ap#
SGMII debug status:0x7 is there an error?
essicka
I'm sorry, I'm stupid. local login is password for login to config.
Your advice helped me and works.
