AP - GUI issue.
Rajan R
Level 5
Level 5
hey guys,
we had two ap's shipped a few days ago which were lap and turned it into autonomous. now the CLI is working fine but the gui has very lmited features. check out the image attached. i am trying to contact tac, since its only a few days there are some issues with contract id and not able to get support. any help is obliged.
Varadarajan.R
12 Replies 12
Stephen Rodriguez
When you connect does it ask you to login? Are the credentials you are using, local to the AP or via TACACS?
Steve
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
credentials are local and it does ask for the login.
Leo Laohoo
The WAPs are probably loaded with an old autonomous IOS, hence this issue.
Version is
C1240 Software (C1240-K9W7-M), Version 12.4(21a)JY
we tried below version on the other ap
C1240 Software (C1240-K9W7-M), Version 12.4(10b)JA3
same error persists.
Have you tried using other browsers?  Like IE or Opera?
So can you console into the ap and issue a show ver?
-Scott
here is the show ver
ahd-aa-ap1200-engineering#sh ver
Cisco IOS Software, C1240 Software (C1240-K9W7-M), Version 12.4(21a)JY, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Wed 28-Apr-10 11:14 by prod_rel_team
ROM: Bootstrap program is C1240 boot loader
BOOTLDR: C1240 Boot Loader (C1240-BOOT-M) Version 12.4(13d)JA, RELEASE SOFTWARE (fc2)
ahd-aa-ap1200-engineering uptime is 40 minutes
System image file is "flash:/c1240-k9w7-mx.124-21a.JY/c1240-k9w7-mx.124-21a.JY"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-LAP1242AG-N-K9   (PowerPCElvis) processor (revision A0) with 24566K/8192K bytes of memory.
Processor board ID FGL1
PowerPCElvis CPU at 262Mhz, revision number 0x0950
Last reset from power-on
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: D8:67:D9:
Part Number                          :
PCA Assembly Number                  :
PCA Revision Number                  : A0
PCB Serial Number                    :
Top Assembly Part Number             : 800-29151-04
Top Assembly Serial Number           :
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1242AG-N-K9
Configuration register is 0xF
no. will try it and get back.. i wonder how browser could be the issue.
Well for example, Cisco suggest you use chrome when accessing the GUI for NCS. You never know.
-Scott
It happens.
tried with chrome and opera.. still the same.
fbarboza
Level 8
Level 8
Try to reset the APs to defaults using the mode button procedure.
http://www.cisco.com/en/US/partner/docs/wireless/access_point/12.3_8_JA/configuration/guide/s38trb.html#wp1058433
If the issue continues then try to relaod the IOS to the units using the mode button procedure.
http://www.cisco.com/en/US/partner/docs/wireless/access_point/12.3_8_JA/configuration/guide/s38trb.html#wp1038660
