AP Join Process - issue - Same gateway prevails
Beacon Bits
Level 4
Level 4
Hi Everyone,
I have set up new WLC-5520 and testing AP 3700 series to join.
Currently no AP is joining the WLC as WLC and AP are in the same subnet.
But I can see on WLC this re-occurring message on the terminal Same gateway prevails
*osapiBsnTimer: Jan 04 11:58:22.299: Same gateway prevails
*osapiBsnTimer: Jan 04 11:58:32.679: Same gateway prevails
*osapiBsnTimer: Jan 04 11:58:43.007: Same gateway prevails
*osapiBsnTimer: Jan 04 11:58:53.387: Same gateway prevails
*osapiBsnTimer: Jan 04 11:59:03.727: Same gateway prevails
Can anyone has insight on this.. is there any config that I'm missing?
S
Beacon Bits
Level 4
Level 4
Thanks everyone.
I have resolved the issue by resetting the AP to default config.
It can be done by GUI... OR
Consoling to AP with command: clear capwap private-config
S
I am seeing this with a 2504 WLC and 3802 APs. I am remote and not able to console in, would be interested in any other possible solution; these are new APs.
Edit: Quick fix for me was I didn't have the proper regulatory domain for these APs.
