AP Joined a WLC with incompatible firmware/code
mattnicomn10
Community Member
For anyone that runs into the same issue.
So, I moved 100+ APs, 3502s, using Prime to a WLC that had updated firmware. The 3502s are not compatible with 8.10.162.0, so the WLC I moved it to showed some CAPWAP errors stating, " no license present with the AP trying to join". We disabled Licensing on it. Using: Config ap cert-expiry-ingore mic enable/disable. It took about 10-15 mins and the APs joined a WLC that was compatible with the 3502s. I then used prime to reconfigure them to the appropriate WLC.
Scott Fella
You always need to look at the compatibility matrix.  Never assume when you upgrade or downgrade or introduce a new device.  If you consoled into the ap, you would see a message stating an error about the code not being supported.  Anyway's, if you don't have it, here is the link to the matrix:
Cisco Wireless Solutions Software Compatibility Matrix - Cisco
-Scott
Rich R
"config ap cert-expiry-ingore mic enable/disable" has nothing to do with licensing - it disables/enables certificate date validity checks.
Like @Scott Fella said you need to read release notes, deployment guides, TAC recommendations and support matrix docs before embarking on major changes.
In this case if "config ap cert-expiry-ingore mic enable/disable" solved your problem then you were hitting the certificate expiry issue very comprehensively documented (and referenced dozens of times on these forums) in the field notice:
https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63942.html
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
