AP Management interface
JLVB83
Level 2
Level 2
Hey folks I have a AIR-LAP1142N-A-K9 in autonomous mode, I have a couple SSID's associated to VLAN's that are working, but in my network I use VLAN 99 to be a management VLAN giving my devices address's to access them, now I'm trying to do the same with this AP with not much luck, from the research and trial and error it seems I need to do something with the BVI interface to get this done, now I don't have anything configured for VLAN 99 in the config at the moment because what I was trying seemed to screw things up.  Here is the config any help will be appreciated.  Thks
Using 2961 out of 32768 bytes
version 12.4
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$rSVx$m9ZCDyyzYmje9ILU5fq3Z/
no aaa new-model
dot11 syslog
dot11 vlan-name MAIN vlan 3
dot11 vlan-name TEMP-WIFI vlan 4
dot11 ssid MAIN-WIFI
vlan 3
authentication shared
mbssid guest-mode
dot11 ssid TEST-WIFI
vlan 4
mbssid guest-mode
username Cisco password 7 032752180500
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
shutdown
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
encryption vlan 4 key 1 size 128bit 7 5FDAC878443167AA9803CCE1230C transmit-key
encryption vlan 4 mode ciphers aes-ccm tkip wep128
encryption vlan 3 key 1 size 128bit 7 E467AA9803CCEEF3D647D478330C transmit-key
encryption vlan 3 mode ciphers aes-ccm tkip wep128
ssid MAIN-WIFI
ssid TEST-WIFI
antenna gain 0
dfs band 3 block
mbssid
speed basic-6.0 basic-9.0 basic-12.0 basic-18.0 basic-24.0 basic-36.0 basic-48.0 basic-54.0 m0. m1. m2. m3. m4. m5. m6. m7. m8. m9. m10. m11. m12. m13. m14. m15.
channel dfs
station-role root
bridge-group 1
interface Dot11Radio1.3
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface Dot11Radio1.4
encapsulation dot1Q 4
no ip route-cache
bridge-group 4
bridge-group 4 subscriber-loop-control
bridge-group 4 block-unknown-source
no bridge-group 4 source-learning
no bridge-group 4 unicast-flooding
bridge-group 4 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
bridge-group 1
interface GigabitEthernet0.3
no ip route-cache
bridge-group 3
interface GigabitEthernet0.4
no ip route-cache
bridge-group 4
interface BVI1
ip address dhcp client-id GigabitEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
line vty 0 4
login local
Sandeep Choudhary
you need to add few commands:
interface GigabitEthernet0.99
encapsulation dot1Q 99 native
bridge-group 1
interface Dot11Radio1.99
bridge-group 1
interface BVI1
ip address <one of the IP in vlan 99>
Dont forget to rate helpful posts
Sandeep Choudhary
bridge-group 1
bridge-group 1
interface BVI1
Thank you, I was missing one thing myself, I did not have my switchport trunk set to native vlan 99, once I did that I could access the AP.
THKS
