AP manager and Management interface subnet
mahesh18
Level 7
Level 7
Hi everyone,
I am trying to setup Wi Fi for client for time.
I am setting up Management subnet for WLC GUI say 10.10.10.x
Need to know interface for AP-Manager has to be on same subnet as 10.10.10.x?
Also for Management IP to WAP it has to be on same subnet as WLC Management interface right?
Mahesh
2 Accepted Solutions
Rasika Nayanajith
What WLC model you using ? if it is 4400,2100  series, yes then you need to put AP manager interface on the same subnet as WLC management.
If it is 5508/2504 series then you do not want AP manager interface. Simply WLC management would do
Rasika
*** Pls rate all useful responses ***
Yes as Rasika said if you are using 5508/2504 series WLCs then you do not required the AP manager interface. Please note that An AP manger can only handle 45 ap each.
Please refer the below link for configuration steps.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_011100.html
6 Replies 6
Rasika Nayanajith
Rasika
Hi Rasika,
I am using wlc 4402.
MAhesh
Mahesh,
Stop wasting on WLC4400.  Read this:  Cisco Mobility Express Bundle
Promo ends 30 June 2015.  Act quickly.
I agree with Leo here:) get the bundle and get a newer model WLC. I'm surprised that the 440x is still working well. The issue is the limited code version that you can get on that model and access point support. Newer clients might have stability issues because how old the code is on the WLC. Standards and enhancement are implemented in the code and this is the same for client end devices. Clients with newer NIC's or NIC's with newer drivers might have issues.  Good luck though... Nice to see that a 440x is still functioning. I have one in my lab, but not constantly powered up.
-Scott
-Scott
Scott,
I've got 6 WiSM-1.  You want to buy them for your museum?  😉
