AP not connecting with controller
aravi9092907772
Community Member
*Jul 20 09:31:06.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 192.168.3.1 peer_port: 5246
*Jul 20 09:31:06.351: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 192.168.3.1 peer_port: 5246
*Jul 20 09:31:06.351: %CAPWAP-5-SENDJOIN: sending Join Request to 192.168.3.1
*Jul 20 09:31:06.595: %DTLS-5-ALERT: Received WARNING : Close notify alert from 192.168.3.1
*Jul 20 09:31:06.595: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 192.168.3.1:5246
*Jul 20 09:31:06.683: %LWAPP-4-CLIENTEVENTLOG: Not sending change state post as the radio admin is down, lrad state = 5
*Jul 20 09:31:06.687: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Jul 20 09:31:06.687: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Jul 20 09:31:06.691: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jul 20 09:31:06.711: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jul 20 09:31:07.691: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jul 20 09:31:07.719: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to down
*Jul 20 09:31:07.727: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Jul 20 09:31:08.711: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jul 20 09:31:08.719: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to down
*Jul 20 09:31:08.747: %LINK-6-UPDOWN: Interface Dot11Radio1, changed state to up
*Jul 20 09:31:08.755: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Jul 20 09:31:08.763: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Jul 20 09:31:09.747: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Jul 20 09:31:09.755: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to down
*Jul 20 09:31:09.783: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to up
*Jul 20 09:31:10.783: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Jul 20 09:31:36.711: AP has SHA2 MIC certificate - Using SHA2 MIC certificate for DTLS.
8 Replies 8
Rasika Nayanajith
Need more info about WLC firmware version & AP model detais
Rasika
Air-CAP2702I-E-K9 Cisco Aironet 2700 series 802.11ac Dual band
L3 switch WLC version 03.06.08E
Hi @aravi9092907772
 It seems certificate problem due expiration timer.  Use the workaround cisco provide
config ap cert-expiry-ignore mic enable
Hi @Flavio Miranda
 Where to type this command as i tried in WLC it says invalid command
it should be on the WLC but it was for AirOS WLC.  Are you running embebded WLC on switch right?
Below option given for 9800 running IOSXE-16.x. Same workaround may work in your case as well
https://www.cisco.com/c/en/us/support/docs/field-notices/639/fn63942.html
C9800 Command to Accept Expired Certificates
configure terminal
crypto pki certificate map map1 1
 issuer-name co cisco manufacturing ca
crypto pki certificate map map1 2
 issuer-name co act2 sudi ca
crypto pki trustpool policy
 match certificate map1 allow expired-certificate
Rasika
*** Pls rate all useful responses ***
Ill try this and get back to you.
yes,
iam running embeded WLC
