WLC5520 8.10.185 - TLS1.2 Using Insecure Ciphers, CBC & SHA
Network713
I have WLC5520 8.10.185.0 (latest version), scan shows that it is uing insecure TLS 1.2 Ciphers CBC & SHA.
Vulnerabilities:
TLS_RSA_WITH_AES_256_CBC_SHA
TLS_RSA_WITH_CAMELLIA_256_CBC_SHA
TLS_RSA_WITH_AES_128_CBC_SHA
TLS_RSA_WITH_CAMELLIA_128_CBC_SHA
I did an nmap and see that these insecure ciphers are available. How do I remove these specific below ciphers on the WLC?
nmap --script ssl-enum-ciphers x.x.x.x
PORT STATE SERVICE
22/tcp open ssh
443/tcp open https
| ssl-enum-ciphers:
| TLSv1.2:
| ciphers:
| TLS_RSA_WITH_AES_256_GCM_SHA384 (rsa 3072) - A
| TLS_RSA_WITH_AES_128_GCM_SHA256 (rsa 3072) - A
| TLS_RSA_WITH_AES_128_CBC_SHA256 (rsa 3072) - A
| TLS_RSA_WITH_AES_256_CBC_SHA256 (rsa 3072) - A
| TLS_RSA_WITH_AES_256_CBC_SHA (rsa 3072) - A            <<<Need to remove, per vulnerability scan
| TLS_RSA_WITH_CAMELLIA_256_CBC_SHA (rsa 3072) - A  <<<Need to remove, per vulnerability scan
| TLS_RSA_WITH_AES_128_CBC_SHA (rsa 3072) - A            <<<Need to remove, per vulnerability scan
| TLS_RSA_WITH_CAMELLIA_128_CBC_SHA (rsa 3072) - A  <<<Need to remove, per vulnerability scan
CURRENT CONIFG:
(Cisco Controller) > show run-config
System Inventory
NAME: "Chassis" , DESCR: "Cisco 5520 Wireless Controller"
PID: AIR-CT5520-K9, VID: V01, SN: xxxx
System Information
Product Version.................................. 8.10.185.0
RTOS Version..................................... 8.10.185.0
Bootloader Version............................... 8.3.15.177
Emergency Image Version.......................... 8.3.141.0
(Cisco Controller) > config network secureweb cipher-option rc4-preference enable
This command has been deprecated!
(Cisco Controller) > show network sum
Web Mode.................................... Disable (disable http access)
Secure Web Mode............................. Enable  (enable https access)
Secure Web Mode Cipher-Option High.......... Enable  (SHA1, SHA256, SHA384 enable & TLSv1.0 disabled)
Secure Web Mode SSL Protocol................ Disable
Web CSRF check.............................. Enable
Secure Shell (ssh).......................... Enable
Secure Shell (ssh) Cipher-Option High....... Enable
Telnet...................................... Disable
Web Auth Secure Web Sslv3 ................. Disable (leave disable, SSL depreciated bc of vulnerabilities, replacement is TLS)
Web Auth Secure Redirection ............... Disable
Web Auth Secure Web ....................... Enable
CLI
1. HTTP Access -not secure
config network webmode {enable | disable}
2. HTTPS Access
config network secureweb {enable | disable}
3. Support larger ciphers: "SHA1, SHA256, SHA384 enable. TLSv1.0 is disabled."
???Cisco would need to remove SHA1 (insecure).
config network secureweb cipher-option high {enable | disable}
4. Not secure, should not use.
config network secureweb cipher-option sslv2 {enable | disable}
5. Enable 256 bit ciphers for a SSH:
config network ssh cipher-option high {enable | disable}
6.
7 Replies 7
Mark Elsen
 - FYI : https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-5/config-guide/b_cg85/administration_of_cisco_wlc.html#ID562
           Also use : https://software.cisco.com/download/home/286284738/type/280926587/release/8.10.185.0
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Rich R
As Marce said step number 1 upgrade to 8.10.185.0 which also resolves other known vulnerabilities.
Did you try this:
Enable or disable preference for RC4-SHA (Rivest Cipher 4-Secure Hash Algorithm) cipher suites (over CBC cipher suites) for web authentication and web administration by entering this command:
config network secureweb cipher-option rc4-preference {enable | disable}
I upgraded to the latest IOS and it is the same result.  WLC still shows that it is using vulnerable CBC & SHA1 ciphers.
System Inventory
System Information
Then I don't think there's anything you can do about it.
The bug Marce mentioned refers to very early versions of 8.10 and is for a different command anyway so I don't think that is relevant.
Mark Elsen
        - FYI : https://bst.cisco.com/bugsearch/bug/CSCvq39439
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Yes, I used the GUI to config cipher high all along.
I upgraded to 8.10.185 and it still shows the same vulnerabilities.
Hi @Network713
https://www.cisco.com/c/en/us/td/docs/wireless/controller/8-10/config-guide/b_cg810/administration_of_cisco_wlc.html
config network secureweb sslv3 {enable | disable}
