AP not join to vWLC
vidyalv00
We have vWLC installed at data center and 5 brand new 2600 wireless APs in the remote office. The APs in remote office get IP and DNS from the local LAN. I tried to let AP initally join the vWLC by layer 3 since it's hard to get vWLC and AP in the same network. Reference from the Cisco doc, add DNS entry for CISCO.LWAPP.CONTROLLER and it's not working. I just wanted to confirm the initial set up has to be on the same network, or there are other way around?
Thanks in advance.
Or on the remote site, globally on the layer 3, you can issues:
ip forward-protocol udp 5246
ip forward-protocol udp 5247
On the svi that the ap's are on, you would issue:
ip helper-address
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
5 Replies 5
Scott Fella
You need to resolve CISCO.CAPWAP.CONTROLLER..com
Scott
-Scott
ip helper-address
Scott
-Scott
Many thanks Scott. That's working!
No problem.... which one did you decide to try?
Scott
-Scott
I tried the ip helper-address. A smart way to make broadcast traffic over routing hop.
