AP not joining vWLC
Kasper Elsborg
Hi community. I have installed an vWLC AIR-CTVM-K9, version 8.5.182.0 - straight from the .ova with standard config. in my ESXI 6.7,  Meaning I haven't changed anything.
I have a couple of AP's cisco AIR-CAP2702I-E-K9 - Cisco IOS Software, C2700 Software (AP3G2-RCVK9W8-M), Version 15.3(3)JA3
that fails to register on the vWLC.
NTP time is current in all Switches and vWLC.
vWLC has 192.168.2.129 in Vlan2
DHCP/DNS has 192.168.2.82
DHCP vendor class are defined, and given the ip of vWLC.
AP's are getting IP from same scope, and are looking for vWLC to join. I can see it in the debug.
I have attaced the booting process and debug capwap client detail, debug capwap mcast
I keep getting the %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
I have searched for this and as suggested, delete flash ap3g2-rcvk9w8* and private-multiple-fs, and erase /all nvram: and reload
didn't work.
Any ideas?
Br. Kasper
Rasika Nayanajith
Check this post & see if you have activated some AP adder licenses
https://community.cisco.com/t5/wireless/issues-moving-ap-onto-new-vwlc/td-p/3926710
Rasika
*** Pls rate all useful responses ***
Rasika Nayanajith
Rasika
Kasper Elsborg
Thanks Rasika Nayanajith
That did the trick
Br. Kasper
