AP not joining
Hi all,
I could need a little help troubleshooting some AP issue.
For some reason some AP will not join the WLC. (WISMII)
I have several hundrede AP online, but still a few offline
This fails:
FRH-R06-L226-UX-G#sh cdp nei gi2/0/41 detail
Device ID: AP5057.a8a1.c632
Entry address(es):
  IP address: 10.61.24.103
Platform: cisco AIR-CAP3502I-E-K9   ,  Capabilities: Trans-Bridge      (why only Trans-Bridge mode and not Capabilities: Router Trans-Bridge)
Interface: GigabitEthernet2/0/41,  Port ID (outgoing port): GigabitEthernet0
Holdtime : 161 sec
Version :
Cisco IOS Software, C3500 Software (AP3G1-RCVK9W8-M), Version 12.4(23c)JA3, RELEASE SOFTWARE (fc1)     (yes recovery image I know)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Tue 18-Oct-11 15:02 by prod_rel_team
advertisement version: 2
Duplex: full
Power drawn: 14.500 Watts     (will it change when AP come online?)
Power request id: 63919, Power management id: 2
Power request levels are:14500 0 0 0 0
Management address(es):
This works fine:
FRH-R06-L226-UX-G#sh cdp nei gi2/0/26 detail
Device ID: AP442b.03c2.638d
Entry address(es):
IP address: 10.61.24.84
Platform: cisco AIR-CAP3502I-E-K9   ,  Capabilities: Router Trans-Bridge
Interface: GigabitEthernet2/0/26,  Port ID (outgoing port): GigabitEthernet0.1
Holdtime : 128 sec
Version :
Cisco IOS Software, C3500 Software (AP3G1-K9W8-M), Version 15.2(2)JB, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Mon 10-Dec-12 23:33 by prod_rel_team
Duplex: full
Power drawn: 15.400 Watts
Power request id: 45452, Power management id: 2
Power request levels are:15400 14500 0 0 0
Switchport config:
interface GigabitEthernet2/0/41
description .1X XG-B-41
switchport access vlan 552
switchport mode access
authentication control-direction in
authentication event fail retry 0 action next-method
authentication event server dead action authorize vlan 552
authentication event server dead action authorize voice
authentication host-mode multi-auth
authentication order dot1x mab
authentication priority dot1x mab
authentication port-control auto
authentication periodic
authentication timer reauthenticate server
mab
dot1x pae authenticator
dot1x timeout quiet-period 5
dot1x timeout tx-period 3
storm-control broadcast level 0.50
storm-control multicast level 0.50
storm-control action shutdown
storm-control action trap
spanning-tree portfast
spanning-tree bpduguard enable
end
I have no access to the console interface on the AP at the moment.
any suggestions
/Finn
Scott Fella
Well you need to take a look at the AP or console. There have been issues with the 3500's and the white light of death. If you can have someone confirm if the APs led is white or not, that will tell you right away if you need to RMA the ap or not. Other than that, you need to console into the AP and post the output when powering up the AP.
-Scott
Leo Laohoo
Get someone to console into the AP in question and enter this command:  config ap controller IP address
Omg. Problem slowed.
Someone created a new VRF for the AP. They forgot to apply firewall rules. No DNS was allowed causing AP unable to resolve DNS name (Cisco-CAPWAP-Controller) for the WLC mgmt address.
Older AP on the location was able to join because they earliere had joinet the WLC and remembered the IP address.
Thanks all for replying.
mmangat
Level 5
Level 5
check if DNS is able to resolve the WLC management address. Thanks
