AP not registering
sqambera
Level 4
Level 4
I have WLC 5520 to which already number of 2802i APs are registered. However, when I am trying to register a new AP it fails. I have noticed that it registers initially but then attempts to download software from the controller. Once the software is downloaded it doesn't register again. Same is indicated in the attached logs.
Can anyone please help?
Qamber
5 Replies 5
Rasika Nayanajith
pls attach (.txt format) that AP console output while you are trying to register it.
Rasika
Leo Laohoo
Post the complete output to the following commands:
1.  WLC:  sh sysinfo; and
2.  AP:  sh version
I am suspecting the AP has the wrong Regulatory Domain.
I think you are probably hitting one of the bugs in 8.3.140.0 which is why that code has been withdrawn.  You should upgrade to 8.3.141.0 asap otherwise you risk losing any of those APs each time they are rebooted.
https://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/crn83mr4.html#whats_new_release_83mr4b
Table 2. Resolved Caveats in Release 8.3.141.0
Caveat ID Number
Description
CSCvi11287
Cisco 2800 AP consistently reboots around 1 second after joining to the WLC
CSCvi14641
Cisco 2802, 3802 APs cannot connect with 100Mbps LAN speed
Rich
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Thanks for your reply. Here are the outputs:
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.3.140.0
RTOS Version..................................... 8.3.140.0
Bootloader Version............................... 8.1.102.0
Emergency Image Version.......................... 8.1.102.0
OUI File Update Time............................. Sun Sep 07 10:44:07 IST 2014
Build Type....................................... DATA + WPS
System Name...................................... PHQ-WLC01
System Location.................................. Edmonton Downtown HQ
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.2170
Redundancy Mode.................................. SSO
IP Address....................................... 10.0.82.10
IPv6 Address..................................... ::
System Up Time................................... 68 days 23 hrs 50 mins 35 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
--More-- or (q)uit
System Stats Normal Interval..................... 180
Configured Country............................... CA - Canada
Operating Environment............................ Commercial (10 to 35 C)
Internal Temp Alarm Limits....................... 10 to 38 C
Internal Temperature............................. +21 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 4
Number of Active Clients......................... 22
OUI Classification Failure Count................. 0
Burned-in MAC Address............................ 00:35:1A:10:7E:41
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 1500
System Nas-Id.................................... Cisco_10:7e:42
WLC MIC Certificate Types........................ SHA1/SHA2
Licensing Type................................... RTU
show ver:
AP Running Image     : 8.3.140.0
Primary Boot Image   : 8.3.140.0
Backup Boot Image    : 8.2.141.0
2 Gigabit Ethernet interfaces
2 802.11 Radios
Radio Driver version : 9.0.5.5-W8964
Radio FW version : 9.1.8.1
NSS FW version :
Base ethernet MAC Address            : A0:E0:AF:2D:2C:A4
Part Number                          : 73-100821-03
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FDO2111174F
Top Assembly Part Number             : 068-100534-01
Top Assembly Serial Number           : FGL2115A15D
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP2802I-A-K9
Thank you everyone for the help. I figured out the problem. The Ethernet wire was not good 🙂
