10-23-2008 06:32 AM - edited 07-03-2021 04:40 PM
Can someone tell me what to look for? I have two SSIDs on an AP: one is WEP and the other is WPA.
I have 5 bars on WEP ssid, but only 2 on the WPA side and eventually down to one.
John
10-25-2008 02:37 PM
Hi John,
Actually your are getting the same signal from both SSID's.
The reason that your are getting 5 bars in one and 2 in the other depands on the OS wireless uitlity.
If you will use a wireless sniffer you could see the RSSI reading in the frame header.
Cheers.
Log in to Community
