I am using 1200 AP's. I noticed that on a couple of our access points, under AP Radio: Internal Advanced, the fowarding state is blocking. When I do a "help" on this it says that the port is blocking transmission. This is the state when no stations are associated. When I look under "Associations" I see that there are several workgroup bridges associated. I also know that the WGB's are working properly. Why can cause the port to say 'blocking" when it appears to be working?
