AP realted issue
raviranjan.p1
Community Member
Hello All,
I am getting the below log as there is continuous fluctuation in AP as there is AP to Ap connectivity ,Please find the version also ,What will will be possible reason for this.
L05A003>sh version
Cisco IOS Software, C1520 Software (C1520-K9W8-M), Version 15.2(4)JB6, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 22-Aug-14 13:14 by prod_rel_team
ROM: Bootstrap program is C1520 boot loader
BOOTLDR: C1520 Boot Loader (C1520-BOOT-M) Version 12.4(3g)JMC, RELEASE SOFTWARE (fc2)
L05A003>show evtlogProcess: Dot11 Offchannel PROCESS
Aug 17 06:40:54.007: %EVT-5-NTC_PROC: mh_driver_off_chnl_complete: to Channel 8 for d0
Process: Dot11 driver
Aug 17 06:40:54.007: %EVT-5-NTC_PROC: dot11_return_serving_channel: d0 Channel 1
Aug 17 06:40:54.007: %EVT-5-NTC_PROC: dot11_return_serving_channel:DFS Enable
Aug 17 06:41:07.615: %EVT-5-NTC_PROC: dot11_set_rm_scan:DFS Disable
Aug 17 06:41:07.803: %EVT-5-NTC_PROC: mh_driver_off_chnl_complete: to Channel 9 for d0
Aug 17 06:41:07.803: %EVT-5-NTC_PROC: dot11_return_serving_channel: d0 Channel 1
Aug 17 06:41:07.803: %EVT-5-NTC_PROC: dot11_return_serving_channel:DFS Enable
Aug 17 06:41:21.411: %EVT-5-NTC_PROC: dot11_set_rm_scan:DFS Disable
Aug 17 06:41:21.591: %EVT-5-NTC_PROC: mh_driver_off_chnl_complete: to Channel 10 for d0
Aug 17 06:41:21.591: %EVT-5-NTC_PROC: dot11_return_serving_channel: d0 Channel 1
Aug 17 06:41:21.591: %EVT-5-NTC_PROC: dot11_return_serving_channel:DFS Enable
Aug 17 06:41:35.207: %EVT-5-NTC_PROC: dot11_set_rm_scan:DFS Disable
Aug 17 06:41:35.387: %EVT-5-NTC_PROC: mh_driver_off_chnl_complete: to Channel 11 for d0
Aug 17 06:41:35.387: %EVT-5-NTC_PROC: dot11_return_serving_channel: d0 Channel 1
Aug 17 06:41:35.387: %EVT-5-NTC_PROC: dot11_return_serving_channel:DFS Enable
Aug 17 06:41:49.003: %EVT-5-NTC_PROC: dot11_set_rm_scan:DFS Disable
Aug 17 06:41:49.183: %EVT-5-NTC_PROC: mh_driver_off_chnl_complete: to Channel 12 for d0
Aug 17 06:41:49.183: %EVT-5-NTC_PROC: dot11_return_serving_channel: d0 Channel 1
Aug 17 06:41:49.183: %EVT-5-NTC_PROC: dot11_return_serving_channel:DFS Enable
Aug 17 06:42:02.335: %EVT-5-NTC_PROC: dot11_set_rm_scan:DFS Disable
Aug 17 06:42:02.507: %EVT-5-NTC_PROC: mh_driver_off_chnl_complete: to Channel 13 for d0
Aug 17 06:42:02.507: %EVT-5-NTC_PROC: dot11_return_serving_channel: d0 Channel 1
Aug 17 06:42:02.507: %EVT-5-NTC_PROC: dot11_return_serving_channel:DFS Enable
Aug 17 06:42:16.131: %EVT-5-NTC_PROC: dot11_set_rm_scan:DFS Disable
Aug 17 06:42:16.295: %EVT-5-NTC_PROC: mh_driver_off_chnl_complete: to Channel 1 for d0
Aug 17 06:42:16.295: %EVT-5-NTC_PROC: dot11_return_serving_channel: d0 Channel 1
Aug 17 06:42:16.295: %EVT-5-NTC_PROC: dot11_return_serving_channel:DFS Enable
Aug 17 06:42:29.927: %EVT-5-NTC_PROC: dot11_set_rm_scan:DFS Disable
Aug 17 06:42:30.091: %EVT-5-NTC_PROC: mh_driver_off_chnl_complete: to Channel 2 for d0
Aug 17 06:42:30.091: %EVT-5-NTC_PROC: dot11_return_serving_channel: d0 Channel 1
Aug 17 06:42:30.091: %EVT-5-NTC_PROC: dot11_return_serving_channel:DFS Enable
Aug 17 06:42:43.723: %EVT-5-NTC_PROC: dot11_set_rm_scan:DFS Disable
Aug 17 06:42:43.879: %EVT-5-NTC_PROC: mh_driver_off_chnl_complete: to Channel 3 for d0
Aug 17 06:42:43.879: %EVT-5-NTC_PROC: dot11_return_serving_channel: d0 Channel 1
Aug 17 06:42:43.879: %EVT-5-NTC_PROC: dot11_return_serving_channel:DFS Enable
Aug 17 06:42:57.519: %EVT-5-NTC_PROC: dot11_set_rm_scan:DFS Disable
Aug 17 06:42:57.679: %EVT-5-NTC_PROC: mh_driver_off_chnl_complete: to Channel 4 for d0
Aug 17 06:42:57.679: %EVT-5-NTC_PROC: dot11_return_serving_channel: d0 Channel 1
Aug 17 06:42:57.679: %EVT-5-NTC_PROC: dot11_return_serving_channel:DFS Enable
Aug 17 06:43:11.315: %EVT-5-NTC_PROC: dot11_set_rm_scan:DFS Disable
Aug 17 06:43:11.471: %EVT-5-NTC_PROC: mh_driver_off_chnl_complete: to Channel 5 for d0
Aug 17 06:43:11.471: %EVT-5-NTC_PROC: dot11_return_serving_channel: d0 Channel 1
Aug 17 06:43:11.471: %EVT-5-NTC_PROC: dot11_return_serving_channel:DFS Enable
Aug 17 06:43:25.111: %EVT-5-NTC_PROC: dot11_set_rm_scan:DFS Disable
Aug 17 06:43:25.267: %EVT-5-NTC_PROC: mh_driver_off_chnl_complete: to Channel 6 for d0
Aug 17 06:43:25.267: %EVT-5-NTC_PROC: dot11_return_serving_channel: d0 Channel 1
Aug 17 06:43:25.267: %EVT-5-NTC_PROC: dot11_return_serving_channel:DFS Enable
Aug 17 06:43:38.907: %EVT-5-NTC_PROC: dot11_set_rm_scan:DFS Disable
Aug 17 06:43:39.055: %EVT-5-NTC_PROC: mh_driver_off_chnl_complete: to Channel 7 for d0
Aug 17 06:43:39.055: %EVT-5-NTC_PROC: dot11_return_serving_channel: d0 Channel 1
Aug 17 06:43:39.055: %EVT-5-NTC_PROC: dot11_return_serving_channel:DFS Enable
Aug 17 06:43:52.703: %EVT-5-NTC_PROC: dot11_set_rm_scan:DFS Disable
Aug 17 06:43:52.851: %EVT-5-NTC_PROC: mh_driver_off_chnl_complete: to Channel 8 for d0
Aug 17 06:43:52.851: %EVT-5-NTC_PROC: dot11_return_serving_channel: d0 Channel 1
Aug 17 06:43:52.851: %EVT-5-NTC_PROC: dot11_return_serving_channel:DFS Enable
Aug 17 06:44:07.055: %EVT-5-NTC_PROC: dot11_set_rm_scan:DFS Disable
Aug 17 06:44:07.199: %EVT-5-NTC_PROC: mh_driver_off_chnl_complete: to Channel 9 for d0
Aug 17 06:44:07.199: %EVT-5-NTC_PROC: dot11_return_serving_channel: d0 Channel 1
Aug 17 06:44:07.199: %EVT-5-NTC_PROC: dot11_return_serving_channel:DFS Enable
Sandeep Choudhary
Must be a bug.
  • CSCuv39290
  • CSCuu02991
Don't forget to rate helpful posts
Hi sandeep ,Thanks for your response ,Is this only the reason  ? ,Anything else apart from this
mohanak
CSCus87673
Symptom:
Dot11Radio1 is getting in the down state due to radio error:
*Feb 5 14:38:46.363: Cmd Timeout After 12s
*Feb 5 14:38:46.363: mvl_handle_timeout called cmdtype=[0x16]
*Feb 5 14:38:46.363: %DOT11-6-GEN_ERROR: Error on Dot11Radio1 -
Radio interface bus down --
-Traceback= 119B108z 17BF0C8z 1829CB4z 182A384z 183773Cz 17C0C24z 17C251Cz 17C4084z 132B150z 1310018z
*Feb 5 14:38:49.103: %CLEANAIR-6-STATE: Slot 1 down
*Feb 5 14:38:51.759: %EVT-4-WRN: Write of flash:/event.r1 done
*Feb 5 14:38:52.371: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to resetPCI reset port 1
*Feb 5 14:38:53.679: soap_pci_reconfig_radio: radio id 1
*Feb 5 14:38:53.695: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to downPCI reset port 1
*Feb 5 14:38:54.031: soap_pci_reconfig_radio: radio id 1
*Feb 5 14:38:54.075: Interface Dot11Radio1: not starting because stop-on-failure set
event.r1 showing the following:
Feb 5 14:38:46.363: %EVT-3-ERR_TRACE: FW: unresponsive thread=0 @B51C69E6,s@B4654338
-Traceback= 1450B40z 1829CACz 182A384z 183773Cz 17C0C24z 17C251Cz 17C4084z 132B150z 1310018z
Feb 5 14:38:46.363: %EVT-5-NTC: Radio d1 FST 79 Flags 2020105 BCN 1
Feb 5 14:38:46.363: %EVT-5-NTC: Radio d1 RST 71 Flags 202010D BCN 1
Feb 5 14:38:46.371: %EVT-5-NTC_PROC: mh_driver_off_chnl_complete: to Channel 11 for d0
Feb 5 14:38:46.371: %EVT-5-NTC_PROC: dot11_return_serving_channel: d0 Channel 6
Feb 5 14:38:46.371: %EVT-5-NTC_PROC: dot11_return_serving_channel:DFS Enable
Conditions:
3700 AP joined to 5760 on 3.3.5SE
Workaround:
Reboot the AP to get radio interface back up
Known Fixed Releases:
(7)
10.2(120.0)
10.3(110.0)
15.3(3)JA4
15.3(3)JA77
15.3(3)JN4
15.3(3)JNB1
8.0(120.0)
Known Affected Releases:
(1)
15.2(4)JB6
