AP - remote office
saquib.tandel
Level 7
Level 7
Hi All
In order to have remote AP connect to centralized WLC do we need specific model of AP on remote site.
remote site is connected to central site with incountry MPLS
To get good handson WLC which is the recommended cisco course to attend
thanks
ST
5 Replies 5
Scott Fella
There is no specific model. You just need to make sure the AP is supported in h-reap/flexconnect.
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080736123.shtml#req
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080b3690b.shtml
-Scott
Scott Fella
As far as training... Depends on where you are located.
http://www.cisco.com/web/learning/le27/learning_learning_partner_connection_home.html
Skyline, Global knowledge and New Horizon are a few in the states.
-Scott
Abhishek Abhishek
Hello ST,
As per your query i can suggest you the following solution-
There is no specific model proposed by Cisco for AP on remote site. And regarding your second query please refer to Cisco Partner Learning.
Hope this will help you.
Thanks Scott / AB
what is the difference between h-reap & flexconnect, when do i configure either of them
They are the same... depends on what code version you are running on the WLC.  It can be refered to as h-reap or with the new code, FlexConnect.  You use them if you have remote sites and you don't want all the traffic to be tunneled back to the WLC.
http://www.cisco.com/en/US/docs/wireless/controller/7.2/configuration/guide/cg_flexconnect.html
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
