C2504 with LAG and VLAN tagging
Jesper Sorensen
Having issues with setting up LAG on a Cisco 2504 WLC and implementing VLAN tagging on the different SSID´s.
Without LAG I had this up and running by using dynamic interfaces and assigning the different SSID´s to a perticular interface which was then assigned a specific VLAN.
However once I enabled LAG on the 2504, the dynamic interfaces became disabled and im unable to find documentation on how to configure VLAN tagging on SSID´s when using LAG.
Relevant info:
Cisco 2504 WLC running 7.4.100.0 (FUS 1.8.0)
Cisco 2602 APs
Cisco 3560 switch running IOS 15 (c3560-ipbasek9-mz.150-2.SE3)
Switch output:
C3560-PoE8#show etherchannel 1 summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SU)          -        Fa0/1(P)    Fa0/2(P)    Fa0/3(P)
                                 Fa0/4(P)
WLC output:
(Cisco Controller) >show lag summary
LAG Enabled
So basically what im trying to achieve is to implement LAG, use 2 SSID´s which are tagged in VLAN 300 and 400 respectively and keep management traffic untagged.
Scott Fella
Did you reboot the WLC after you enabled LAG?
-Scott
Hi Scott,
Yes I did.. But it seems that after deselecting the "Interface/Interface Group(G)" under the SSID´s and then selecting the dynamic interface again that the problem is resolved.
