AP's not appearing in Prime
Jamie Hancock
Recently, when we install new AP's they show up on our controllers but not on our Cisco Prim NCS 1.1 server??
Could someone help me diagnose this problem please?
Jamie.
8 Replies 8
Leo Laohoo
In some cases, it would take about 30 minutes before the APs show up.
Thanks for the reply.
Its been weeks! So I dont think that is the issue.
J.
Your WLC version is v7.2.x or lower right?
-Scott
I have several different models.
4402 - 7.0.240
4404 - 7.0.240
5505 - 7.4.110
Jamie
Your 5508 isn't supported in NCS 1.1.  So your AP's on the 4400's should be seen, but not the 5508.  See the matrix.
http://www.cisco.com/en/US/docs/wireless/controller/5500/tech_notes/Wireless_Software_Compatibility_Matrix.html#wp99431
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Typical Cisco!!!!!
So does this mean I have to upgrade NCS??
J.
Hi Jamie,
We had similer problem, we have rebooted the NCS. after that we are able to see  AP's in NCS
even recently we have problem with addind Autonomus AP's. Same solution....dont know Y
Satya.M
I have tried that but it hasn't worked.
J.
