3702i won't join controller
Wes Schochet
Level 7
Level 7
Just unboxed my first new 3700 AP.   Fired it up and it doesn't appar to like my controller.  Anyone have any suggestions?
IOS Bootloader - Starting system.
flash is writable
Tide XL MB - 40MB of flash
Xmodem file system is available.
flashfs[0]: 12 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 7354880
flashfs[0]: Bytes available: 33803776
flashfs[0]: flashfs fsck took 10 seconds.
Base Ethernet MAC address: 3c:08:f6:6c:f5:04
Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx"...##########################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
Boot CMD: 'boot  flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx;flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx'
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"...######################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx" uncompressed and installed, entry point: 0x1003000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C3700 Software (AP3G2-RCVK9W8-M), Version 15.2(4)JB1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Sat 16-Nov-13 10:46 by prod_rel_team
Initializing flashfs...
flashfs[2]: 12 files, 2 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 40900608
flashfs[2]: Bytes used: 7354880
flashfs[2]: Bytes available: 33545728
flashfs[2]: flashfs fsck took 10 seconds.
flashfs[2]: Initialization complete.
flashfs[3]: 0 files, 1 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 11999232
flashfs[3]: Bytes used: 1024
flashfs[3]: Bytes available: 11998208
flashfs[3]: flashfs fsck took 1 seconds.
flashfs[3]: Initialization complete.
Copying radio files from flash: to ram:
%Error opening flash:/ap3g2-rcvk9w8-mx/E2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/B2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/V2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/X2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/Y2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/R2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/Q2.bin (No such file or directory)
%Error opening flash:/ap3g2-rcvk9w8-mx/C2.bin (No such file or directory)
Uncompressing radio files...
File not found: flash:/ap3g2-rcvk9w8-mx/8004.img
File not found: flash:/ap3g2-rcvk9w8-mx/E5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/B5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/V5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/X5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/Y5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/R5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/Q5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/C5.bin
File not found: flash:/ap3g2-rcvk9w8-mx/8006.img
...done Initializing flashfs.
no ip http server
% Invalid input detected at '^' marker.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco AIR-CAP3702I-A-K9 (PowerPC) processor (revision A0) with 204790K/57344K bytes of memory.
Processor board ID FTX175071RZ
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 7.6.1.118
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 3C:08:F6:6C:F5:04
Part Number                          : 73-15243-01
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : FOC17482H3B
Top Assembly Part Number             : 068-05054-01
Top Assembly Serial Number           : FTX175071RZ
Top Revision Number                  : A0
Product/Model Number                 : AIR-CAP3702I-A-K9
% Please define a domain-name first.
Press RETURN to get started!
APAVC: Initial WLAN Buffers Given to System is  2500
APAVC:  WlanPAKs 18174 RadioPaks  17566
set_radio_pwr_mode: bad radio unit# 0
set_radio_pwr_mode: bad radio unit# 1
*Mar  1 00:00:13.663: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:15.707: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:16.067: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:16.107: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:16.107: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default configlwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:16.231: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar  1 00:00:17.095: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to upERROR: Failed to configure ethernet promiscuous mode. Interface Descriptor mismatch
*Mar  1 00:00:20.919: DPAA Initialization Complete
*Mar  1 00:00:20.919: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar  1 00:00:21.919: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
no bridge-group 1 source-learning
%Default route without gateway, if not a point-to-point interface, may impact performance
*Mar  1 00:00:34.859: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:53.751: %DHCP-6-ADDRESS_ASSIGN: Interface BVI1 assigned DHCP address 10.13.1.85, mask 255.255.254.0, hostname AP3c08.f66c.f504
Translating "CISCO-CAPWAP-CONTROLLER.childrenshc.org"...domain server (10.12.18.255)
*Mar  1 00:01:03.731: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.11.0.210 obtained through DHCP
*Mar  1 00:01:03.731: %CAPWAP-5-DHCP_OPTION_43: Controller address 10.11.0.212 obtained through DHCP
*Mar  1 00:01:03.731: %CAPWAP-3-ERRORLOG: Did not get log server settings from DHCP.
*Mar  1 00:01:03.731: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLER.childrenshc.org
*Mar  1 00:01:03.735: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'c5508-2.cpt'running version 7.5.102.0 is rejected.
*Mar  1 00:01:03.735: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
*Mar  1 00:01:03.735: %CAPWAP-3-ERRORLOG: CAPWAP SM handler: Failed to process message type 2 state 2.
*Mar  1 00:01:03.735: %CAPWAP-3-ERRORLOG: Failed to handle capwap control message from controller
*Mar  1 00:01:03.735: %CAPWAP-3-ERRORLOG: Failed to process unencrypted capwap packet from 10.11.0.212
*Mar  1 00:01:13.735: %CAPWAP-3-ERRORLOG: Discovery response from MWAR 'c5508-2.cpt'running version 7.5.102.0 is rejected.
*Mar  1 00:01:13.735: %CAPWAP-3-ERRORLOG: Failed to decode discovery response.
10 Replies 10
Wes Schochet
Level 7
Level 7
The release notes (http://www.cisco.com/en/US/docs/wireless/access_point/3700/quick/guide/ap3700getstart.html#wp41694) say code ver 7.5.0.0, but I am beyond that at 7.5.102.0.  Somehow, I think a code upgrade is still in my future!
Wes,
     on the WLC CLI can you capture and post the output of the follwoing debugs?
debug mac addr 3c08f66cf504
debug capwap events enable
debug capwap errors enable
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH,
Steve
What code is the WLC 7.5 ? 3700 require 7.6 code ..
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
Hang tight I just emailed the cisco guys on the 3700 team ..
Just confirmed with the Cisco guys, thats a mistake. 7.6 code is needed, 7.5 not supported with 3700.
Nothing like a good hex dump to get the day going!
Hi Wes,
Talk to TAC & get a pre-release 7.6.x code & check this AP registration again..
There may be a chance this AP get corrupted since it was connected to a controller image which is not supported.(but you should be able to recover it)
Rasika
**** Pls rate all useful responses ****
Create a TAC Case.
TAC will give you special release access to a pre-release 7.6 firmware.
yes.
