AP Serial Number Summary from WLC
dseagren1
I'm just wondering if there is a way to get an output of the serial numbers of all the APs connected to a WLC. I know they can be individually found in the WLC web interface or through the CLI but i'm hoping to find a way to see them all.
thanks
18 Replies 18
vasuandvasu619
config paging enable
grep include "PID:" "show ap inventory all"
This command will give all serial numbers, just copy and past it in Excel sheet. In Excel Data menu, there is an option text to columns-> it will open a popup and click next ->next
CSCO11514622
Tank You very much Arshad
You can also bind this command : for exemple  inventory
alias exec inventory show ap config general | i Cisco AP Name|AP Serial Number|AP Model|Cisco AP Identifier
WLC01#inventory
Cisco AP Name : AP_01
Cisco AP Identifier : ac2a.xxxx.xxx1
AP Model : C9120AXI-E
AP Serial Number : FCWyyyyyyyy
Cisco AP Name : AP_02
Cisco AP Identifier : ac2a.xxxx.xxx2
etc...
eng amr fouad
I personally use the following command
show ap config general | i AP Serial Number|Cisco AP Name
FFFFFFFaTING
hey everybody ! the solution is here. in monitor,edit colunms,and select SN,then export to excel,or you can show ap name xxx inventory via cli.
