AP settings - Global Properties
ney25
Level 7
Level 7
Hi netpro,
let me share with you some background first, currently my AP has 3 Radius server which mainly for redundancy, incase Radius server A down, server B will take over. but, lately i noticed when my Server A , Server B never take over and i saw some logs which indicating Dead Server .... bla bla bla.
anyone can tell me how to configure AP - Global Properties for redundancy.
your reply will be highly appreciated.
thanks.
regards,
Jack
Scott Fella
Looking at the configuration, the only thing you have to change is to enable the dead radious server list and set it to 1 min which is the minimum. So it would take at least a minute before the ap tries the 2nd radious server. Test it to see how it reacts when server 1 comes back online.
-Scott
Hi Fella5,
thanks for your information but i noticed if the Radius server is not down , example : when u do a ping command , radius server still replied with packets although Services down . but the Radius server wont fail over to Radius server B . i have encountered this problem which means i need to manually change the server priority .
is that any solution for this ?
thanks.
regards,
Jack
