05-21-2019 09:05 AM - edited 07-05-2021 10:26 AM
I am trying to register Cisco AP 2600i series to a vWLC and it remain stuck:
May 21 16:56:26.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_i p: 10.70.1.6 peer_port: 5246
*May 21 16:56:26.231: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.70.1.6 peer_port: 5246
*May 21 16:56:26.231: %CAPWAP-5-SENDJOIN: sending Join Request to 10.70.1.6
*May 21 16:56:31.231: %CAPWAP-5-SENDJOIN: sending Join Request to 10.70.1.6
*May 21 16:57:25.999: %DTLS-5-SEND_ALERT: Send FATAL : Close notify Alert to 10. 70.1.6:5246
I am using vWLC 8.2
has anyone experienced this
Solved! Go to Solution.
05-22-2019 10:51 AM
I believe this could be the issue
License Eula: Not Accepted
If you go to "Management > Licenses " add AP count & hit "Set count" button.
Then it should prompt you to accept EULA agreement. Then test it again & see
Rasika
*** Pls rate all useful responses ***
05-21-2019 09:48 AM
check this threads may help you :
https://community.cisco.com/t5/wireless-and-mobility/ap-fails-to-join-controller/td-p/1354902
05-22-2019 12:33 AM
05-22-2019 08:01 AM
(Cisco Controller) >show sys?
sysinfo syslog system
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.2.166.0
RTOS Version..................................... 8.2.166.0
Bootloader Version............................... 8.3.15.96
Emergency Image Version.......................... 8.2.166.0
Build Type....................................... DATA + WPS
System Name...................................... WLC-82
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1631
IP Address....................................... 10.70.1.6
IPv6 Address..................................... ::
System Up Time................................... 0 days 0 hrs 3 mins 40 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... FR - France
--More-- or (q)uit
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 1
Number of Active Clients......................... 0
Burned-in MAC Address............................ 00:0C:29:FE:09:D5
Maximum number of APs supported.................. 200
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1
Licensing Type................................... RTU
vWLC config...................................... Small
(Cisco Controller) >show time
Time............................................. Wed May 22 17:55:06 2019
Timezone delta................................... 0:0
Timezone location................................ (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
NTP Servers
NTP Polling Interval......................... 9600
Index NTP Key Index NTP Server Status NTP Msg Auth Status
1 0 10.20.1.2 In Sync AUTH DISABLED
APbc16.6595.c337#sh version
Cisco IOS Software, C2600 Software (AP3G2-K9W8-M), Version 15.3(3)JC, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Fri 11-Dec-15 11:51 by prod_rel_team
ROM: Bootstrap program is C2600 boot loader
BOOTLDR: C2600 Boot Loader (AP3G2-BOOT-M) LoaderVersion 12.4(25e)JAY, RELEASE SOFTWARE (fc1)
APbc16.6595.c337 uptime is 9 minutes
System image file is "flash:/ap3g2-k9w8-mx.153-3.JC/ap3g2-k9w8-xx.153-3.JC"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP2602I-E-K9 (PowerPC) processor (revision A0) with 188398K/60928K bytes of memory.
Processor board ID FGL1717X3WL
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.2.100.0
1 Gigabit Ethernet interface
2 802.11 Radios
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: BC:16:65:95:C3:37
Part Number : 73-14588-02
PCB Serial Number : FOC17162QAW
Top Assembly Part Number : 800-38356-01
Top Assembly Serial Number : FGL1717X3WL
Top Revision Number : A0
Product/Model Number : AIR-CAP2602I-E-K9
Configuration register is 0xF
APbc16.6595.c337#
APbc16.6595.c337#
APbc16.6595.c337#sh inv
APbc16.6595.c337#sh inventory
NAME: "AP2600", DESCR: "Cisco Aironet 2600 Series (IEEE 802.11n) Access Point"
PID: AIR-CAP2602I-E-K9 , VID: V01, SN: FGL1717X3WL
05-22-2019 09:19 AM
Below two command on vWLC will provide more useful information about this failure.
debug capwap events enable
debug capwap errors enable
debug disable-all is the command to stop debugging.
If you have many APs on this vWLC, then better to filer using "debug client <mac_addr>" to filter single AP mac address.
Rasika
05-22-2019 09:51 AM
please see below
(Cisco Controller) >debug capwap errors enable
(Cisco Controller) >debug capwap errors enable *spamApTask6: May 22 19:41:26.204: f4:1f:c2:32:fd:40 Discovery Request from 10.70.1.11:23604
*spamApTask6: May 22 19:41:26.204: f4:1f:c2:32:fd:40 ApModel: AIR-CAP2602I-E-K9
*spamApTask6: May 22 19:41:26.204: f4:1f:c2:32:fd:40 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 200, joined Aps =0
*spamApTask6: May 22 19:41:26.204: apModel: AIR-CAP2602I-E-K9
*spamApTask6: May 22 19:41:26.204: apType = 27 apModel: AIR-CAP2602I-E-K9
*spamApTask6: May 22 19:41:26.204: apType: Ox1b bundleApImageVer: 8.2.166.0
*spamApTask6: May 22 19:41:26.204: version:8 release:2 maint:166 build:0
*spamApTask6: May 22 19:41:26.204: f4:1f:c2:32:fd:40 Discovery Response sent to 10.70.1.11 port 23604
*spamApTask6: May 22 19:41:26.204: f4:1f:c2:32:fd:40 Discovery Response sent to 10.70.1.11:23604
*spamApTask6: May 22 19:41:26.205: f4:1f:c2:32:fd:40 Discovery Request from 10.70.1.11:23604
*spamApTask6: May 22 19:41:26.205: f4:1f:c2:32:fd:40 ApModel: AIR-CAP2602I-E-K9
*spamApTask6: May 22 19:41:26.205: f4:1f:c2:32:fd:40 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 200, joined Aps =0
*spamApTask6: May 22 19:41:26.205: apModel: AIR-CAP2602I-E-K9
*spamApTask6: May 22 19:41:26.205: apType = 27 apModel: AIR-CAP2602I-E-K9
*spamApTask6: May 22 19:41:26.205: apType: Ox1b bundleApImageVer: 8.2.166.0
*spamApTask6: May 22 19:41:26.205: version:8 release:2 maint:166 build:0
*spamApTask6: May 22 19:41:26.205: f4:1f:c2:32:fd:40 Discovery Response sent to 10.70.1.11 port 23604
*spamApTask6: May 22 19:41:26.205: f4:1f:c2:32:fd:40 Discovery Response sent to 10.70.1.11:23604
*osapiBsnTimer: May 22 19:41:27.439: bc:16:65:95:c3:37 Wait join timer expired for connection 10.70.1.11:23605
*spamApTask7: May 22 19:41:27.439: bc:16:65:95:c3:37 Disconnecting due to a wait join timer expiry event for (10.70.1.11:23605) server details (10.70.1.6:5246)
*spamApTask7: May 22 19:41:27.439: f4:1f:c2:32:fd:40 Found DTLS connection 0x8bc85d0, disconnecting it
*spamApTask7: May 22 19:41:27.440: bc:16:65:95:c3:37 Deleting AP entry 10.70.1.11:23605 from temporary database.
*spamApTask7: May 22 19:41:27.440: f4:1f:c2:32:fd:40 DTLS connection closed event receivedserver (10.70.1.6/5246) client (10.70.1.11/23605)
*spamApTask7: May 22 19:41:27.440: f4:1f:c2:32:fd:40 No entry exists for AP (10.70.1.11/23605)
*spamApTask7: May 22 19:41:27.440: f4:1f:c2:32:fd:40 No AP entry exist in temporary database for 10.70.1.11:23605
*spamApTask6: May 22 19:41:36.202: bc:16:65:95:c3:37 DTLS connection not found, creating new connection for 10:70:1:11 (23604) 10:70:1:6 (5246)
*spamApTask6: May 22 19:41:36.436: bc:16:65:95:c3:37 DTLS Session established server (10.70.1.6:5246), client (10.70.1.11:23604)
*spamApTask6: May 22 19:41:36.436: bc:16:65:95:c3:37 Starting wait join timer for AP: 10.70.1.11:23604
*spamApTask6: May 22 19:41:36.437: f4:1f:c2:32:fd:40 Join Request from 10.70.1.11:23604
*spamApTask6: May 22 19:41:36.438: update ap status:00:00:00:00:00:00 ,index:8
*spamApTask6: May 22 19:41:36.438: Unable to find deleted AP 00:00:00:00:00:00
*spamApTask6: May 22 19:41:36.438: f4:1f:c2:32:fd:40 Failed to allocate database entry for AP 10.70.1.11:23604
*spamApTask6: May 22 19:41:36.438: f4:1f:c2:32:fd:40 Failed to add database entry for 10.70.1.11:23604
*spamApTask6: May 22 19:41:36.438: f4:1f:c2:32:fd:40 Join Request failed!
*spamApTask6: May 22 19:41:36.438: f4:1f:c2:32:fd:40 State machine handler: Failed to process msg type = 3 state = 0 from 10.70.1.11:23604
*spamApTask6: May 22 19:41:36.438: f4:1f:c2:32:fd:40 Failed to parse CAPWAP packet from 10.70.1.11:23604
*spamApTask6: May 22 19:41:41.434: f4:1f:c2:32:fd:40 Join Request from 10.70.1.11:23604
*spamApTask6: May 22 19:41:41.434: update ap status:00:00:00:00:00:00 ,index:9
*spamApTask6: May 22 19:41:41.435: Unable to find deleted AP 00:00:00:00:00:00
*spamApTask6: May 22 19:41:41.435: f4:1f:c2:32:fd:40 Failed to allocate database entry for AP 10.70.1.11:23604
*spamApTask6: May 22 19:41:41.435: f4:1f:c2:32:fd:40 Failed to add database entry for 10.70.1.11:23604
*spamApTask6: May 22 19:41:41.435: f4:1f:c2:32:fd:40 Join Request failed!
*spamApTask6: May 22 19:41:41.435: f4:1f:c2:32:fd:40 State machine handler: Failed to process msg type = 3 state = 0 from 10.70.1.11:23604
*spamApTask6: May 22 19:41:41.435: f4:1f:c2:32:fd:40 Failed to parse CAPWAP packet from 10.70.1.11:23604
*spamApTask7: May 22 19:42:36.318: f4:1f:c2:32:fd:40 Discovery Request from 10.70.1.11:23605
*spamApTask7: May 22 19:42:36.318: f4:1f:c2:32:fd:40 ApModel: AIR-CAP2602I-E-K9
*spamApTask7: May 22 19:42:36.318: f4:1f:c2:32:fd:40 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 200, joined Aps =0
*spamApTask7: May 22 19:42:36.319: apModel: AIR-CAP2602I-E-K9
*spamApTask7: May 22 19:42:36.319: apType = 27 apModel: AIR-CAP2602I-E-K9
*spamApTask7: May 22 19:42:36.319: apType: Ox1b bundleApImageVer: 8.2.166.0
*spamApTask7: May 22 19:42:36.319: version:8 release:2 maint:166 build:0
*spamApTask7: May 22 19:42:36.319: f4:1f:c2:32:fd:40 Discovery Response sent to 10.70.1.11 port 23605
*spamApTask7: May 22 19:42:36.319: f4:1f:c2:32:fd:40 Discovery Response sent to 10.70.1.11:23605
*spamApTask7: May 22 19:42:36.319: f4:1f:c2:32:fd:40 Discovery Request from 10.70.1.11:23605
*spamApTask7: May 22 19:42:36.319: f4:1f:c2:32:fd:40 ApModel: AIR-CAP2602I-E-K9
*spamApTask7: May 22 19:42:36.319: f4:1f:c2:32:fd:40 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 200, joined Aps =0
*osapiBsnTimer: May 22 19:42:37.615: bc:16:65:95:c3:37 Wait join timer expired for connection 10.70.1.11:23604
*spamApTask6: May 22 19:42:37.615: bc:16:65:95:c3:37 Disconnecting due to a wait join timer expiry event for (10.70.1.11:23604) server details (10.70.1.6:5246)
*spamApTask6: May 22 19:42:37.615: f4:1f:c2:32:fd:40 Found DTLS connection 0x8bc8820, disconnecting it
*spamApTask6: May 22 19:42:37.616: bc:16:65:95:c3:37 Deleting AP entry 10.70.1.11:23604 from temporary database.
*spamApTask6: May 22 19:42:37.616: f4:1f:c2:32:fd:40 DTLS connection closed event receivedserver (10.70.1.6/5246) client (10.70.1.11/23604)
*spamApTask6: May 22 19:42:37.616: f4:1f:c2:32:fd:40 No entry exists for AP (10.70.1.11/23604)
*spamApTask6: May 22 19:42:37.616: f4:1f:c2:32:fd:40 No AP entry exist in temporary database for 10.70.1.11:23604
*spamApTask7: May 22 19:42:46.317: bc:16:65:95:c3:37 DTLS connection not found, creating new connection for 10:70:1:11 (23605) 10:70:1:6 (5246)
*spamApTask7: May 22 19:42:46.550: bc:16:65:95:c3:37 DTLS Session established server (10.70.1.6:5246), client (10.70.1.11:23605)
*spamApTask7: May 22 19:42:46.550: bc:16:65:95:c3:37 Starting wait join timer for AP: 10.70.1.11:23605
*spamApTask7: May 22 19:42:46.552: f4:1f:c2:32:fd:40 Join Request from 10.70.1.11:23605
*spamApTask7: May 22 19:42:46.552: update ap status:00:00:00:00:00:00 ,index:10
*spamApTask7: May 22 19:42:46.552: Unable to find deleted AP 00:00:00:00:00:00
*spamApTask7: May 22 19:42:46.552: f4:1f:c2:32:fd:40 Failed to allocate database entry for AP 10.70.1.11:23605
*spamApTask7: May 22 19:42:46.552: f4:1f:c2:32:fd:40 Failed to add database entry for 10.70.1.11:23605
*spamApTask7: May 22 19:42:46.552: f4:1f:c2:32:fd:40 Join Request failed!
*spamApTask7: May 22 19:42:46.552: f4:1f:c2:32:fd:40 State machine handler: Failed to process msg type = 3 state = 0 from 10.70.1.11:23605
*spamApTask7: May 22 19:42:46.552: f4:1f:c2:32:fd:40 Failed to parse CAPWAP packet from 10.70.1.11:23605
*spamApTask7: May 22 19:42:51.549: f4:1f:c2:32:fd:40 Join Request from 10.70.1.11:23605
*spamApTask7: May 22 19:42:51.549: update ap status:00:00:00:00:00:00 ,index:11
*spamApTask7: May 22 19:42:51.549: Unable to find deleted AP 00:00:00:00:00:00
*spamApTask7: May 22 19:42:51.549: f4:1f:c2:32:fd:40 Failed to allocate database entry for AP 10.70.1.11:23605
*spamApTask7: May 22 19:42:51.549: f4:1f:c2:32:fd:40 Failed to add database entry for 10.70.1.11:23605
*spamApTask7: May 22 19:42:51.549: f4:1f:c2:32:fd:40 Join Request failed!
*spamApTask7: May 22 19:42:51.549: f4:1f:c2:32:fd:40 State machine handler: Failed to process msg type = 3 state = 0 from 10.70.1.11:23605
*spamApTask7: May 22 19:42:51.549: f4:1f:c2:32:fd:40 Failed to parse CAPWAP packet from 10.70.1.11:23605
*spamApTask6: May 22 19:43:46.429: f4:1f:c2:32:fd:40 Discovery Request from 10.70.1.11:23604
*spamApTask6: May 22 19:43:46.429: f4:1f:c2:32:fd:40 ApModel: AIR-CAP2602I-E-K9
*spamApTask6: May 22 19:43:46.429: f4:1f:c2:32:fd:40 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 200, joined Aps =0
*spamApTask6: May 22 19:43:46.429: apModel: AIR-CAP2602I-E-K9
*spamApTask6: May 22 19:43:46.429: apType = 27 apModel: AIR-CAP2602I-E-K9
*spamApTask6: May 22 19:43:46.429: apType: Ox1b bundleApImageVer: 8.2.166.0
*spamApTask6: May 22 19:43:46.429: version:8 release:2 maint:166 build:0
*spamApTask6: May 22 19:43:46.429: f4:1f:c2:32:fd:40 Discovery Response sent to 10.70.1.11 port 23604
*spamApTask6: May 22 19:43:46.429: f4:1f:c2:32:fd:40 Discovery Response sent to 10.70.1.11:23604
*spamApTask6: May 22 19:43:46.430: f4:1f:c2:32:fd:40 Discovery Request from 10.70.1.11:23604
*spamApTask6: May 22 19:43:46.430: f4:1f:c2:32:fd:40 ApModel: AIR-CAP2602I-E-K9
*spamApTask6: May 22 19:43:46.430: f4:1f:c2:32:fd:40 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 200, joined Aps =0
*spamApTask6: May 22 19:43:46.430: apModel: AIR-CAP2602I-E-K9
*spamApTask6: May 22 19:43:46.430: apType = 27 apModel: AIR-CAP2602I-E-K9
*spamApTask6: May 22 19:43:46.430: apType: Ox1b bundleApImageVer: 8.2.166.0
*spamApTask6: May 22 19:43:46.430: version:8 release:2 maint:166 build:0
*spamApTask6: May 22 19:43:46.430: f4:1f:c2:32:fd:40 Discovery Response sent to 10.70.1.11 port 23604
*spamApTask6: May 22 19:43:46.430: f4:1f:c2:32:fd:40 Discovery Response sent to 10.70.1.11:23604
*osapiBsnTimer: May 22 19:43:47.587: bc:16:65:95:c3:37 Wait join timer expired for connection 10.70.1.11:23605
*spamApTask7: May 22 19:43:47.587: bc:16:65:95:c3:37 Disconnecting due to a wait join timer expiry event for (10.70.1.11:23605) server details (10.70.1.6:5246)
*spamApTask7: May 22 19:43:47.587: f4:1f:c2:32:fd:40 Found DTLS connection 0x8bc8a70, disconnecting it
*spamApTask7: May 22 19:43:47.587: bc:16:65:95:c3:37 Deleting AP entry 10.70.1.11:23605 from temporary database.
*spamApTask7: May 22 19:43:47.587: f4:1f:c2:32:fd:40 DTLS connection closed event receivedserver (10.70.1.6/5246) client (10.70.1.11/23605)
*spamApTask7: May 22 19:43:47.587: f4:1f:c2:32:fd:40 No entry exists for AP (10.70.1.11/23605)
*spamApTask7: May 22 19:43:47.587: f4:1f:c2:32:fd:40 No AP entry exist in temporary database for 10.70.1.11:23605
*spamApTask6: May 22 19:43:56.427: bc:16:65:95:c3:37 DTLS connection not found, creating new connection for 10:70:1:11 (23604) 10:70:1:6 (5246)
*spamApTask6: May 22 19:43:56.661: bc:16:65:95:c3:37 DTLS Session established server (10.70.1.6:5246), client (10.70.1.11:23604)
*spamApTask6: May 22 19:43:56.661: bc:16:65:95:c3:37 Starting wait join timer for AP: 10.70.1.11:23604
*spamApTask6: May 22 19:43:56.662: f4:1f:c2:32:fd:40 Join Request from 10.70.1.11:23604
*spamApTask6: May 22 19:43:56.663: update ap status:00:00:00:00:00:00 ,index:12
*spamApTask6: May 22 19:43:56.663: Unable to find deleted AP 00:00:00:00:00:00
*spamApTask6: May 22 19:43:56.663: f4:1f:c2:32:fd:40 Failed to allocate database entry for AP 10.70.1.11:23604
*spamApTask6: May 22 19:43:56.663: f4:1f:c2:32:fd:40 Failed to add database entry for 10.70.1.11:23604
*spamApTask6: May 22 19:43:56.663: f4:1f:c2:32:fd:40 Join Request failed!
*spamApTask6: May 22 19:43:56.663: f4:1f:c2:32:fd:40 State machine handler: Failed to process msg type = 3 state = 0 from 10.70.1.11:23604
*spamApTask6: May 22 19:43:56.663: f4:1f:c2:32:fd:40 Failed to parse CAPWAP packet from 10.70.1.11:23604
*spamApTask6: May 22 19:44:01.659: f4:1f:c2:32:fd:40 Join Request from 10.70.1.11:23604
*spamApTask6: May 22 19:44:01.659: update ap status:00:00:00:00:00:00 ,index:13
*spamApTask6: May 22 19:44:01.659: Unable to find deleted AP 00:00:00:00:00:00
*spamApTask6: May 22 19:44:01.659: f4:1f:c2:32:fd:40 Failed to allocate database entry for AP 10.70.1.11:23604
*spamApTask6: May 22 19:44:01.659: f4:1f:c2:32:fd:40 Failed to add database entry for 10.70.1.11:23604
*spamApTask6: May 22 19:44:01.659: f4:1f:c2:32:fd:40 Join Request failed!
*spamApTask6: May 22 19:44:01.659: f4:1f:c2:32:fd:40 State machine handler: Failed to process msg type = 3 state = 0 from 10.70.1.11:23604
*spamApTask6: May 22 19:44:01.659: f4:1f:c2:32:fd:40 Failed to parse CAPWAP packet from 10.70.1.11:23604
*spamApTask7: May 22 19:44:56.544: f4:1f:c2:32:fd:40 Discovery Request from 10.70.1.11:23605
*spamApTask7: May 22 19:44:56.544: f4:1f:c2:32:fd:40 ApModel: AIR-CAP2602I-E-K9
*spamApTask7: May 22 19:44:56.544: f4:1f:c2:32:fd:40 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 200, joined Aps =0
*spamApTask7: May 22 19:44:56.544: apModel: AIR-CAP2602I-E-K9
*spamApTask7: May 22 19:44:56.544: apType = 27 apModel: AIR-CAP2602I-E-K9
*spamApTask7: May 22 19:44:56.544: apType: Ox1b bundleApImageVer: 8.2.166.0
*spamApTask7: May 22 19:44:56.544: version:8 release:2 maint:166 build:0
*spamApTask7: May 22 19:44:56.544: f4:1f:c2:32:fd:40 Discovery Response sent to 10.70.1.11 port 23605
*spamApTask7: May 22 19:44:56.544: f4:1f:c2:32:fd:40 Discovery Response sent to 10.70.1.11:23605
*spamApTask7: May 22 19:44:56.545: f4:1f:c2:32:fd:40 Discovery Request from 10.70.1.11:23605
*spamApTask7: May 22 19:44:56.545: f4:1f:c2:32:fd:40 ApModel: AIR-CAP2602I-E-K9
*spamApTask7: May 22 19:44:56.545: f4:1f:c2:32:fd:40 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 200, joined Aps =0
*spamApTask7: May 22 19:44:56.545: apModel: AIR-CAP2602I-E-K9
*spamApTask7: May 22 19:44:56.545: apType = 27 apModel: AIR-CAP2602I-E-K9
*spamApTask7: May 22 19:44:56.545: apType: Ox1b bundleApImageVer: 8.2.166.0
*spamApTask7: May 22 19:44:56.545: version:8 release:2 maint:166 build:0
*spamApTask7: May 22 19:44:56.545: f4:1f:c2:32:fd:40 Discovery Response sent to 10.70.1.11 port 23605
*spamApTask7: May 22 19:44:56.545: f4:1f:c2:32:fd:40 Discovery Response sent to 10.70.1.11:23605
*osapiBsnTimer: May 22 19:44:57.763: bc:16:65:95:c3:37 Wait join timer expired for connection 10.70.1.11:23604
*spamApTask6: May 22 19:44:57.763: bc:16:65:95:c3:37 Disconnecting due to a wait join timer expiry event for (10.70.1.11:23604) server details (10.70.1.6:5246)
*spamApTask6: May 22 19:44:57.763: f4:1f:c2:32:fd:40 Found DTLS connection 0x8bc8cc0, disconnecting it
*spamApTask6: May 22 19:44:57.763: bc:16:65:95:c3:37 Deleting AP entry 10.70.1.11:23604 from temporary database.
*spamApTask6: May 22 19:44:57.763: f4:1f:c2:32:fd:40 DTLS connection closed event receivedserver (10.70.1.6/5246) client (10.70.1.11/23604)
*spamApTask6: May 22 19:44:57.763: f4:1f:c2:32:fd:40 No entry exists for AP (10.70.1.11/23604)
*spamApTask6: May 22 19:44:57.763: f4:1f:c2:32:fd:40 No AP entry exist in temporary database for 10.70.1.11:23604
*spamApTask7: May 22 19:45:06.542: bc:16:65:95:c3:37 DTLS connection not found, creating new connection for 10:70:1:11 (23605) 10:70:1:6 (5246)
*spamApTask7: May 22 19:45:06.774: bc:16:65:95:c3:37 DTLS Session established server (10.70.1.6:5246), client (10.70.1.11:23605)
*spamApTask7: May 22 19:45:06.775: bc:16:65:95:c3:37 Starting wait join timer for AP: 10.70.1.11:23605
*spamApTask7: May 22 19:45:06.776: f4:1f:c2:32:fd:40 Join Request from 10.70.1.11:23605
*spamApTask7: May 22 19:45:06.776: update ap status:00:00:00:00:00:00 ,index:14
*spamApTask7: May 22 19:45:06.776: Unable to find deleted AP 00:00:00:00:00:00
*spamApTask7: May 22 19:45:06.776: f4:1f:c2:32:fd:40 Failed to allocate database entry for AP 10.70.1.11:23605
*spamApTask7: May 22 19:45:06.776: f4:1f:c2:32:fd:40 Failed to add database entry for 10.70.1.11:23605
*spamApTask7: May 22 19:45:06.776: f4:1f:c2:32:fd:40 Join Request failed!
*spamApTask7: May 22 19:45:06.776: f4:1f:c2:32:fd:40 State machine handler: Failed to process msg type = 3 state = 0 from 10.70.1.11:23605
*spamApTask7: May 22 19:45:06.776: f4:1f:c2:32:fd:40 Failed to parse CAPWAP packet from 10.70.1.11:23605
*spamApTask7: May 22 19:45:11.774: f4:1f:c2:32:fd:40 Join Request from 10.70.1.11:23605
*spamApTask7: May 22 19:45:11.774: update ap status:00:00:00:00:00:00 ,index:15
*spamApTask7: May 22 19:45:11.774: Unable to find deleted AP 00:00:00:00:00:00
*spamApTask7: May 22 19:45:11.774: f4:1f:c2:32:fd:40 Failed to allocate database entry for AP 10.70.1.11:23605
*spamApTask7: May 22 19:45:11.774: f4:1f:c2:32:fd:40 Failed to add database entry for 10.70.1.11:23605
*spamApTask7: May 22 19:45:11.774: f4:1f:c2:32:fd:40 Join Request failed!
*spamApTask7: May 22 19:45:11.774: f4:1f:c2:32:fd:40 State machine handler: Failed to process msg type = 3 state = 0 from 10.70.1.11:23605
*spamApTask7: May 22 19:45:11.774: f4:1f:c2:32:fd:40 Failed to parse CAPWAP packet from 10.70.1.11:23605
*spamApTask6: May 22 19:46:06.654: f4:1f:c2:32:fd:40 Discovery Request from 10.70.1.11:23604
*spamApTask6: May 22 19:46:06.654: f4:1f:c2:32:fd:40 ApModel: AIR-CAP2602I-E-K9
*spamApTask6: May 22 19:46:06.654: f4:1f:c2:32:fd:40 Join Priority Processing status = 0, Incoming Ap's Priority 1, MaxLrads = 200, joined Aps =0
*spamApTask6: May 22 19:46:06.654: apModel: AIR-CAP2602I-E-K9
*spamApTask6: May 22 19:46:06.654: apType = 27 apModel: AIR-CAP2602I-E-K9
*spamApTask6: May 22 19:46:06.654: apType: Ox1b bundleApImageVer: 8.2.166.0
*spamApTask6: May 22 19:46:06.654: version:8 release:2 maint:166 build:0
*spamApTask6: May 22 19:46:06.654: f4:1f:c2:32:fd:40 Discovery Response sent to 10.70.1.11 port 23604
*spamApTask6: May 22 19:46:06.654: f4:1f:c2:32:fd:40 Discovery Response sent to 10.70.1.11:23604
*spamApTask6: May 22 19:46:06.655: f4:1f:c2:32:fd:40 Discovery Response sent to 10.70.1.11 port 23604
*spamApTask6: May 22 19:46:06.655: f4:1f:c2:32:fd:40 Discovery Response sent to 10.70.1.11:23604
*osapiBsnTimer: May 22 19:46:07.938: bc:16:65:95:c3:37 Wait join timer expired for connection 10.70.1.11:23605
*spamApTask7: May 22 19:46:07.938: bc:16:65:95:c3:37 Disconnecting due to a wait join timer expiry event for (10.70.1.11:23605) server details (10.70.1.6:5246)
*spamApTask7: May 22 19:46:07.938: f4:1f:c2:32:fd:40 Found DTLS connection 0x8bc8f10, disconnecting it
*spamApTask7: May 22 19:46:07.939: bc:16:65:95:c3:37 Deleting AP entry 10.70.1.11:23605 from temporary database.
*spamApTask7: May 22 19:46:07.939: f4:1f:c2:32:fd:40 DTLS connection closed event receivedserver (10.70.1.6/5246) client (10.70.1.11/23605)
*spamApTask7: May 22 19:46:07.939: f4:1f:c2:32:fd:40 No entry exists for AP (10.70.1.11/23605)
deb*spamApTask7: May 22 19:46:07.939: f4:1f:c2:32:fd:40 No AP entry exist in temporary database for 10.70.1.11:23605
*spamApTask6: May 22 19:46:16.652: bc:16:65:95:c3:37 DTLS connection not found, creating new connection for 10:70:1:11 (23604) 10:70:1:6 (5246)
*spamApTask6: May 22 19:46:16.885: bc:16:65:95:c3:37 DTLS Session established server (10.70.1.6:5246), client (10.70.1.11:23604)
*spamApTask6: May 22 19:46:16.885: bc:16:65:95:c3:37 Starting wait join timer for AP: 10.70.1.11:23604
*spamApTask6: May 22 19:46:16.887: f4:1f:c2:32:fd:40 Join Request from 10.70.1.11:23604
*spamApTask6: May 22 19:46:16.887: update ap status:00:00:00:00:00:00 ,index:16
*spamApTask6: May 22 19:46:16.887: Unable to find deleted AP 00:00:00:00:00:00
*spamApTask6: May 22 19:46:16.887: f4:1f:c2:32:fd:40 Failed to allocate database entry for AP 10.70.1.11:23604
*spamApTask6: May 22 19:46:16.887: f4:1f:c2:32:fd:40 Failed to add database entry for 10.70.1.11:23604
*spamApTask6: May 22 19:46:16.887: f4:1f:c2:32:fd:40 Join Request failed!
*spamApTask6: May 22 19:46:16.887: f4:1f:c2:32:fd:40 State machine handler: Failed to process msg type = 3 state = 0 from 10.70.1.11:23604
*spamApTask6: May 22 19:46:16.887: f4:1f:c2:32:fd:40 Failed to parse CAPWAP packet from 10.70.1.11:23604
de*spamApTask6: May 22 19:46:21.884: f4:1f:c2:32:fd:40 Join Request from 10.70.1.11:23604
*spamApTask6: May 22 19:46:21.884: update ap status:00:00:00:00:00:00 ,index:17
*spamApTask6: May 22 19:46:21.884: Unable to find deleted AP 00:00:00:00:00:00
*spamApTask6: May 22 19:46:21.884: f4:1f:c2:32:fd:40 Failed to allocate database entry for AP 10.70.1.11:23604
*spamApTask6: May 22 19:46:21.884: f4:1f:c2:32:fd:40 Failed to add database entry for 10.70.1.11:23604
*spamApTask6: May 22 19:46:21.884: f4:1f:c2:32:fd:40 Join Request failed!
*spamApTask6: May 22 19:46:21.884: f4:1f:c2:32:fd:40 State machine handler: Failed to process msg type = 3 state = 0 from 10.70.1.11:23604
*spamApTask6: May 22 19:46:21.884: f4:1f:c2:32:fd:40 Failed to parse CAPWAP packet from 10.70.1.11:23604
Incorrect input! Use 'debug capwap [events/errors/info/detail] [enable/disable]
(Cisco Controller) >debug disable-all
Thanks Bol
05-22-2019 10:09 AM
Pls post "show license summary" & "show auth-list" output as well.
Rasika
05-22-2019 10:19 AM
Hi Rasika,
pls see below
(Cisco Controller) >show license summary
Feature name: ap_count
License type: Evaluation
Evaluation total period: 12 week s 6 days
License state: Active, Not-In-Use
RTU License Count: 200
Evaluation total period: 12 weeks 6 days
(Cisco Controller) >show auth-list ?
Authorize MIC APs against Auth-list or AAA ...... disabled
Authorize LSC APs against Auth-List ............. disabled
APs Allowed to Join
AP with Manufacturing Installed Certificate.... yes
AP with Self-Signed Certificate................ yes
AP with Locally Significant Certificate........ no
Mac Addr Cert Type Key Hash
bc:16:65:95:c3:37 SSC 5ef1d1d9ea4ede422c008800b66b6b8a42465ed3
Bol
05-22-2019 10:51 AM
Rasika
05-22-2019 12:21 PM
05-22-2019 12:55 PM - edited 05-22-2019 12:58 PM
Glad to hear
You need to change AP mode to FlexConnect in order to advertise SSIDs as only that mode support in vWLC
Rasika
05-23-2019 01:23 AM
you are the best. Thanks a billion times
05-23-2019 02:03 AM
Good news indeed. Thanks for rating our responses as well.
08-05-2020 09:23 AM
Legend... many thanks :)
05-04-2021 12:20 AM
thank you so much, had the same issue on 3702i, joined perfectly now with my vWLC, again thank you.
