AP Wireless SAP2602E Autonomous interminttent Client
I have an SAP 2602E AP configure in  autonomous with Version 15.2(2)JA,client getting intermittent connection when associate to this AP.
any experience with this case? I appreciate any help.
un 18 02:10:14.893: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   0c77.1ae9.b6e0 Associated KEY_MGMT[WPAv2 PSK]
Jun 18 02:10:52.528: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  4c3c.16de.3709 Associated KEY_MGMT[WPAv2 PSK]
Jun 18 02:11:11.924: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   a85b.7897.cd45 Reassociated KEY_MGMT[WPAv2 PSK]
Jun 18 02:11:23.980: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   6420.0cdc.cef0 Associated KEY_MGMT[WPAv2 PSK]
 --More--         Jun 18 02:11:28.171: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 6420.0cdc.cef0 Reason: Sending station has left the BSS
Jun 18 02:11:28.183: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   6420.0cdc.cef0 Reassociated KEY_MGMT[WPAv2 PSK]
Jun 18 02:11:47.875: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4c3c.16de.3709 Reason: Sending station has left the BSS
Jun 18 02:11:47.919: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  4c3c.16de.3709 Associated KEY_MGMT[WPAv2 PSK]
Jun 18 02:11:50.227: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0c77.1ae9.b6e0 Reason: Sending station has left the BSS
Jun 18 02:12:04.099: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   34a3.957b.12f2 Reassociated KEY_MGMT[WPAv2 PSK]
Jun 18 02:12:35.930: %DOT11-6-ROAMED: Station a85b.7897.cd45 Roamed to 5478.1aab.43f0
Jun 18 02:12:35.930: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station a85b.7897.cd45 Reason: Sending station has left the BSS
Jun 18 02:12:45.542: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 6420.0cdc.cef0 Reason: Previous authentication no longer valid
Jun 18 02:12:48.290: %DOT11-6-ROAMED: Station 34a3.957b.12f2 Roamed to 5478.1ad0.a750
Jun 18 02:12:48.290: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 34a3.957b.12f2 Reason: Sending station has left the BSS
Jun 18 02:15:20.185: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 4c3c.16de.3709 Reason: Sending station has left the BSS
 --More--         Jun 18 02:22:13.382: %DOT11-7-AUTH_FAILED: Station 406f.2abf.99b2 Authentication failed
Jun 18 02:23:43.554: %DOT11-4-CCMP_REPLAY: Client 7014.a6ae.b6e6 had 1 AES-CCMP TSC replays
Jun 18 02:23:59.554: %DOT11-4-CCMP_REPLAY: Client 7014.a6ae.b6e6 had 1 AES-CCMP TSC replays
Jun 18 02:33:15.410: %DOT11-7-AUTH_FAILED: Station 70d4.f295.2289 Authentication failed
Jun 18 02:34:17.823: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   8832.9bdd.8fe3 Associated KEY_MGMT[WPAv2 PSK]
Jun 18 02:35:04.812: %DOT11-6-ROAMED: Station 8832.9bdd.8fe3 Roamed to 5478.1ad0.a750
Jun 18 02:35:04.812: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 8832.9bdd.8fe3 Reason: Sending station has left the BSS
Jun 18 02:39:50.929: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   80be.051f.e350 Associated KEY_MGMT[WPAv2 PSK]
Jun 18 02:39:51.349: %DOT11-7-AUTH_FAILED: Station 70d4.f295.2289 Authentication failed
Jun 18 02:40:16.636: %DOT11-6-ROAMED: Station 80be.051f.e350 Roamed to c800.8460.1ce0
Jun 18 02:40:16.636: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 80be.051f.e350 Reason: Sending station has left the BSS
Jun 18 02:44:48.309: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   8863.df1a.efae Reassociated KEY_MGMT[WPAv2 PSK]
 --More--         Jun 18 02:44:50.533: %DOT11-6-ROAMED: Station 8863.df1a.efae Roamed to 5478.1ad0.0610
Jun 18 02:44:50.533: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 8863.df1a.efae Reason: Sending station has left the BSS
Jun 18 02:45:41.540: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 7014.a6ae.b6e6 Reason: Previous authentication no longer valid
Jun 18 02:47:44.303: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   0c77.1ae9.b6e0 Associated KEY_MGMT[WPAv2 PSK]
Jun 18 02:49:47.574: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   7014.a6ae.b6e6 Associated KEY_MGMT[WPAv2 PSK]
Jun 18 02:49:49.410: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 7014.a6ae.b6e6 Reason: Sending station has left the BSS
Jun 18 02:49:49.438: %DOT11-6-ASSOC: Interface Dot11Radio1, Station   7014.a6ae.b6e6 Reassociated KEY_MGMT[WPAv2 PSK]
Jun 18 02:49:49.654: %DOT11-6-ROAMED: Station 0c77.1ae9.b6e0 Roamed to 5478.1aab.43f0
Jun 18 02:49:49.654: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0c77.1ae9.b6e0 Reason: Sending station has left the BSS
Jun 18 02:49:51.789: %DOT11-6-DISASSOC: Interface Dot11Radio1, Deauthenticating Station 7014.a6ae.b6e6 Reason: Sending station has left the BSS
Do you have more than one AP?  The reason Inask is that the output show that devices have roamed to another AP.  if you have another AP, is it the same model or do you have a mixed environment.  How you contest the AP is to create a test SSID that is open and try to associate. If successful, then next step is to use WPA2/AES psk and test again. You need to create a new SSID for this test. If your device works fine, then you might have to try to verify the psk for the existing SSID or something else, but at least you have done some testing to eliminate the AP or SSID configurations.
-Scott
-Scott
Hi Scott,
thanks for your advise,yes we have another one AP with the same model and SSID.
the problem is the client already associated to the SSID,but suddenly the client lost the connection,it happen on several time.i will try your advise.thank you.
