AP with MBSSID with only 1 SSID connecting?
srosenthal
Level 4
Level 4
I have an autonomous 1130AG configured with 3 SSID's on 3 vlan's.  The first SSID uses EAP-FAST, the second SSID uses LEAP and the third SSID uses WPA-PSK.  I am using the Cisco abg card with the Cisco ADU.  I have configured all three SSID's on the ADU but can only get a link on the WPA-PSK ssid.  When I select one of the first two SSID's, I do not even get a link to even try to authenticate.
Anyone have any idea's what might be going on?  I can see all of the SSID's when I use the scan feature of the ADU and have tried the same setup on two other AP's with know luck.  All three SSID's are configured with mbssid guess-mode.
Seth
srosenthal
Level 4
Level 4
I have reconfigured the AP to just one SSID using EAP-FAST and I still cannot even get a link on the ADU.  Here is the config from the AP.  I am seeing the SSID when I use the scan function of the ADU.
service password-encryption
hostname 1130a
enable secret 5 $1$zx2l$SmmwKW13XmXdiQlbrJ/m//
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap1
server 192.168.1.26 auth-port 1812 acct-port 1813
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods1 group rad_eap1
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 ssid Lab03a
   authentication open eap eap_methods1
   authentication key-management wpa version 2
   guest-mode
   infrastructure-ssid optional
power inline negotiation prestandard source
username Cisco password 7 106D000A0618
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm
ssid Lab03a
channel 2412
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 172.23.20.20 255.255.255.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.1.26 auth-port 1812 acct-port 1813 key 7 060506324F41
radius-server vsa send accounting
bridge 1 route ip
line con 0
line vty 0 4
end
