AP1131 replacement
wfqk
Level 7
Level 7
AP1131's max speed is about 27 Mbps, which is very slow. If we want to upgrade it, which AP we can use to replace it? thank you
Mark Elsen
 Start with the link below and follow guidelines (or subsequent-links) according to your needs :
           https://www.cisco.com/c/en/us/products/wireless/access-points/index.html
M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
