AP1142N & AIR-PWRINJ3 compatibility
ltobal
We're deploying a project composed by AP1142N and AIR-PWRINJ3. The UTP patch cords are Category 5E. The access points work normally when powered by external power sources ( PWR-B= ). The problem occurs when access points are powered by the power injectors ( AIR-PWRINJ3 ). So, I ask for your help to the questions below:
1) The power injectors "AIR-PWRINJ3" are compatible to AP1142N, aren't ?
2) Is there some suggested procedure to troubleshooting this scenario ?
Leonardo.
Surendra BG
1142 AP requires AIR-PWRINJ4 power injector.. i have seen many issues like this using PWRINJ3..  the below datasheet will let us know..
http://www.cisco.com/en/US/prod/collateral/wireless/ps5678/ps10092/datasheet_c78-502793.html
Surendra
Surendra BG
