Ap1200 Boot problem
k.mahmood
I am woundering if someone could help me, actually I was trying to upgrade my ap1200 with the latest image (c1200-k9w7-tar.122-15.JA.tar), while upgrading, it stops automatically, Now when I rebbot it, it show as below:
ap: Xmodem file system is available.
flashfs[0]: 2 files, 1 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 2048
flashfs[0]: Bytes available: 7739392
flashfs[0]: flashfs fsck took 7 seconds.
Reading cookie from flash parameter block...done.
Base ethernet MAC Address: 00:0b:5f:55:38:35
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
link auto-negotiating....
auto-negotiation takes 10000 milli-seconds to complete
ERROR: timeout waiting for auto-negotiation to complete
ERROR: fail to bring ethernet link up
The system has been encountered an error initializing
ethernet port. You may need to check hardware
The system is ignoring the error and continuint boot.
If you interrupt the system boot process, the following
commands will reinitialize ethernet, tftp, and finish
loading the operating system software:
ether_init
tftp_init
boot
The system is unable to boot automatically because there
are no bootable files to boot.
C1200 Boot Loader (C1200-BOOT-M) Version 12.2(8)JA, EARLY DEPLOYMENT RELEASE SOF
TWARE (fc1)
TAC Support: http://www.cisco.com/tac
Compiled Wed 12-Feb-03 15:23 by hqluong
or if I use command dir, it shows as below:
List of filesystems currently registered:
flash[0]: (read-write)
xmodem[1]: (read-only)
null[2]: (read-write)
I think that there is no file in flash.
If I am in this situation, how can I upload the file on ap1200 via console, I have also tried the MODE Button procedure but it does not work at all, and I am getting two red lead on my ap1200.
I am hoping to get the soultion ASASP, am very much upset.
regards
Khaleefa
stuart_over
Community Member
Hi there,
I had the same problem the other day and posted on here. Check out the post called firmware to IOS problem. it explains how to get the image back onto the ap.
Alo noticed that the ap failed to bring up the ethernet port, was it connected to the network?
Anyway hope it helps you out...
Stu...
