AP1200 Loses Connectivity
pallette
I have an AP1200 that looses connectivity internmittently to the network. This is the only AP1200 I have. I do not experience this problem with any AP340 or AP350's. If I start a continous ping from the wireless client, at certain points the ping will time out. As well as if I start a ping on the AP1200 ip address from a worstation that is not on the wireless network, I will see that the AP1200 is loosing connectivity, not the wireless client. The time outs will occur at the same time. Anybody have any clues. I have check the switchport on the catalyst switch, and there are no errors, nor does the switchport go up and down. All seems to be connected fine.
derwin
Level 5
Level 5
Which version of firmware ?
I am running version 12.01T
