AP1252 tkip errors - HELP!
tsrader
Level 3
Level 3
Have 4 AP1252 installed.  Clients dropping off wireless every 20 min.
Multiple clients running HP  tablets are dropping often and unable to connect for a period of time.   Log files on WAP show TKIP MICHAEL MIC errors.  Have already configured  the  "countermeasure tkip hold-time 0" but that hasnt fixed issue  either.
WAPs running on power injectors (non-PoE)
4 WAPs within 100ft due to obstructions
     Power setting: 14
     Client power:  max
Can someone post a baseline 802.11n working config which can be used to get at least one WAP working?
Any help is appreciated.
Config attached:
Nicolas Darchis
by the way, you will never achieve 11n speeds with WPA1-TKIP configured. 11n standards require the ssid to only run WPA2-AES. That was for the side note.
For the rest, those failures would most likely come from the client drivers rather than the access point. Which IOS version do you have ?
Nicolas.
