AP1262N AN Radio configuration (autonomous)
michael.frey
Recently installed a 1262N AP in autonomous mode. Have both 2.4 and 5Ghz radios running- Both on separate SSID and VLAN.  I think I have 5Ghz channels using 40Mhz bands (bonded) but when I do iperf throughput test I only get about 25Mb throughput. I am sitting within 10 feet of the AP. When I switch to 2.4 I get around 60Mb and that's not bonded. I have tried multiple interfaces on my client side laptop I'm testing with since I thought maybe it was a quirky card or driver but I get same results. Am I doing something wrong here?  My laptop shows a 300Mb connection to 5Ghz and 144Mb on 2.4Ghz but I know that's not true thorughput so that's why I was testing this to see what I was really getting and now I'm confused.
Thanks!
Leo Laohoo
Stupid question from me:  Do you have all SIX antennas attached?  If you do, please specify what models you are are using.
Yes 3 2.2 Dbi 2.4Ghz antennas and 3 3.5 Dbi 5Ghz ones. Part Numbers. AIR-ANT2422DW and AIR-ANT5135DW.
Ok, on the autonomous WAP, run the command "sh dot11 ass " and on the client side, what is the signal strength.
Back to the WAP, please run the following command:
dot11 dot111 carrier busy
dot11 dot110 carrier busy
Do the "sh log" and please post the output or result.
OK commands are a little off but I think I got what you asked for. Highlighted is the laptop I'm on.
mfrey-cisapupstairs#sho dot11 statistics client-traffic interface dot11Radio 1
Dot11Radio1: -- Client Statistics
---Clients     AID VLAN     Status   Age Tx   Mode Enc Key      Rate
0021.6a98.b068   2 3193 00 140 000 0FE 20   1-1 7F80 200 0-10 00FFFFFF 40E 80F
70de.e22b.1e3b   1 3193 00 160 000 0FE 26   0-0 3180 200 0-10 00FFFF00 107 107
                 RxPkts KBytes Dup Dec Mic   TxPkts KBytes Retry RSSI SNR
0021.6a98.b068   21729   2718   4   0   0   12250   5392   2837   64 27
70de.e22b.1e3b   13120   507 305   0   0     1165     232   603   66 26
               IP Address     Pauses   RSC
0021.6a98.b068 10.31.93.100   00000 [0]0x2E29
70de.e22b.1e3b 10.31.93.103   00000 [0]0x2D1
   Block Ack Pri, Rcv Wind Timeout SeqNum Held, Xmt Wind Timeout
0021.6a98.b068   0       64     5000   E2A0   0       64       31 0, 0 0 0
70de.e22b.1e3b   0       64       0   C1A0   0         8       0 0, 0 0 0
Video Report: Cnt Rate Retries/Tot
8021x auth in prog -23 allowed 0
mfrey-cisapupstairs#sho dot11 carrier busy
Frequency  Carrier Busy %
   5180          0
   5200          1
   5220          2
   5240          1
   5260          1
   5280          0
   5300          2
   5320          0
   5500          2
   5520          1
   5540          0
   5560          0
   5580          0
   5660          0
   5680          0
   5700          0
   5745          0
   5765          1
   5785          2
   5805          0
   5825          1
   2412         14
   2417          6
   2422          2
   2427          0
   2432          2
   2437          7
   2442          4
   2447          5
   2452          2
   2457          8
   2462         15
