AP1852I
FickoHGP
Community Member
I am looking for solution how to solve problem with Cisco AP - AIR-AP1852I-E-K9, which for some reason disconnect from the WLC and cannot register again.
I tried to reset it on factory - but still.
Version of WLC
AIR-CT5520-K9
8.2.166.0
Here is a part of Console output
[*03/30/2023 05:55:50.9172] Discovery response from MWAR ''running version 0.0.0.0 is rejected.
[*03/30/2023 05:55:50.9172] Failed to decode discovery response.
[*03/30/2023 05:55:50.9172] CAPWAP SM handler: Failed to process message type 2 state 2.
[*03/30/2023 05:55:50.9172] Failed to handle capwap control message from controller - status 4
[*03/30/2023 05:55:50.9172] Failed to process unencrypted capwap packet from 10.1.2.251
[*03/30/2023 05:55:50.9172] Failed to send capwap message 0 to the state machine. Packet already freed.
[*03/30/2023 05:55:50.9172] wtpProcessPacketFromSocket returned 4
[*03/30/2023 05:56:00.4142] CAPWAP State: Discovery
[*03/30/2023 05:56:00.4142] Discovery Request sent to 10.1.2.251, discovery type STATIC_CONFIG(1)
[*03/30/2023 05:56:00.4142] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
[*03/30/2023 05:56:00.4142] Discovery Response from 10.1.2.251
[*03/30/2023 05:56:00.4142] This AP model is supported by controller version newer than 7.0.0.0!
[*03/30/2023 05:56:00.4142] Discovery response from MWAR ''running version 0.0.0.0 is rejected.
[*03/30/2023 05:56:00.4142] Failed to decode discovery response.
[*03/30/2023 05:56:00.4142] CAPWAP SM handler: Failed to process message type 2 state 2.
[*03/30/2023 05:56:00.4142] Failed to handle capwap control message from controller - status 4
[*03/30/2023 05:56:00.4142] Failed to process unencrypted capwap packet from 10.1.2.251
[*03/30/2023 05:56:00.4142] Failed to send capwap message 0 to the state machine. Packet already freed.
[*03/30/2023 05:56:00.4142] wtpProcessPacketFromSocket returned 4
Mar 30 05:56:01 apsw_watchdog: secs_no_lighttpd: 0
Mar 30 05:56:01 apsw_watchdog: secs_no_slowfcgi: 0
Mar 30 05:56:01 apsw_watchdog: secs_no_sync_log: 0
Mar 30 05:56:01 apsw_watchdog: secs_no_syslogd: 0
Mar 30 05:56:01 apsw_watchdog: secs_no_hostapd: 0
Mar 30 05:56:01 apsw_watchdog: secs_no_gateway: 0
Mar 30 05:56:01 apsw_watchdog: secs_no_dnsmasq: 0
Mar 30 05:56:01 apsw_watchdog: secs_no_xmit_mon0: 0
Mar 30 05:56:01 apsw_watchdog: secs_no_xmit_mon1: 0
Mar 30 05:56:01 apsw_watchdog: secs_no_xmit_mon2: 0
Writing reload timestamp (Thu Mar 30 05:56:06 UTC 2023) to disk
[03/30/2023 05:56:07.7919] UBIFS: un-mount UBI device 0, volume 3
The system is going down NOW!
Sent SIGTERM to all processes
[*03/30/2023 05:56:07.9219] device capwap0 left promiscuous mode
[*03/30/2023 05:56:07.9619] device capwap1 left promiscuous mode
Sent SIGKILL to all processes
Requesting system reboot16]
[03/30/2023 05:56:09.9113] Restarting system.
[03/30/2023 05:56:09.9513] Going down for restart now
KWC23150300:
[*04/16/2023 21:50:59.6214] DOT11_DRV[1]: wifi1 acfg cmd 2 failed for wifi1 errno 19(No such device)
KWC2201078X:
[*04/12/2023 12:37:10.9503] DOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver get_vap_if_index ioctl SIOCGIFINDEX failed for apr1v0 error No such device
And various other similar messages.  The hardware has failed - RMA the APs.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
10 Replies 10
Mark Elsen
   - The controller software version is very old use :
                                https://software.cisco.com/download/home/286284738/type/280926587/release/8.10.185.0
   (upgrade the wireless controller software)
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Dear Marce,
Thank you for your email and reply.
The problem is that these APs work well for 2 year, and for some reason,
they start crashing and disconnecting from WLC.
We know that we should update, but still have some models of AP that
support only the current version of WLC.
AIR-AP1852I-E-K9 // 76 pcs
AIR-LAP1142N-E-K9 // 18 pcs
AIR-AP1572EAC-E-K9 // 1 pcs
AIR-CAP1532I-E-K9 // 2 pcs
AIR-CAP1702I-E-K9 // 25pcs
The highest version of WLC which supports all 5 models of APs is 8.3.150.0.
Is there any way that we can manually install images to problematic APs?
   - Checkout https://bst.cisco.com/bugsearch/bug/CSCvf71074
 M.
Rich R
This is almost certainly a hardware failure of the AP requiring RMA.
Attach the complete log from the AP console from power here as a .txt file (don't paste the whole log in here).
That should show when the AP detects hardware failure (eg missing radios) which causes the AP join to fail because it sends malformed join requests to the WLC.  The hardware failure rate on the 18xx APs is higher than on other models - we RMA about 20 per month on average.
FickoHGP
Community Member
Thank you for your replay.
I am attaching console out from two APs with same error.
KWC23150300:
KWC2201078X:
FickoHGP
Community Member
Yes, probably it is hardware failure.
Thank you !
Do Tien Dung
Level 3
Level 3
Try switching it back to Mobility Express mode
video tutorials:
https://www.youtube.com/watch?v=zo91OsLpwwY
Thanks & Best Regards,
Do Tien Dung
Technical staff - Service support department
IT Operations Center
57 Huynh Thuc Khang Street, Dong Da District,
Ha Noi Capital, Viet Nam
www.vnptit.vn
live:.cid.edce5e4917b06b34
Cisco provides two types of firmware for access point wave 2 (1815i, 1832i, 1852i, 2802i, 3802i..) Lightweight and Mobility Express. Mobility Express is firmware that allows the access point to act as a virtual controller that can administer other Lightweight APs in the network. However, not AP is
@Do Tien Dung are you suggesting that converting the AP to Mobility Express will magically repair the failed hardware?
If the hardware is faulty, I think RMA should be, and if the Access Point's software is faulty, I think it should be updated to the latest version.
Do Tien Dung
www.vnptit.vn
