AP2802 Failed to start Cisco act2 check
NicoMat
Hi!
I have an air-ap2802i, which is rebooting and showing the message below.
The wireless controller is: WLC5520 ver. 8.10.142.
Do you know any workaround or just RMA?
[ OK ] Created slice -.slice.
[ OK ] Created slice system.slice.
Starting Cisco system time setup...
[*03/07/2019 23:59:59.0067] Last reload time: Mar 10 12:56:15 2020
[*03/10/2020 12:56:15.0001] Setting system time Tue Mar 10 12:56:15 UTC 2020
Starting Cisco kexec...
[ OK ] Reached target Slices.
Starting Cisco seed generation...
Starting Cisco act2 check...
[*03/10/2020 12:56:15.3805]
[*03/10/2020 12:56:15.3805] (write)Unable to open I2C device in Starting Cisco early mount...
Starting Cisco platform file generation...
[ OK ] Created slice system-serial\x2dgetty.slice.
[ OK ] Reached target Sockets.
[ OK ] Reached target Timers.
[ OK ] Started Cisco system time setup.
[ OK ] Started Cisco kexec.
[ OK ] Started Cisco seed generation.
[ OK ] Started Cisco early mount.
[ OK ] Started Cisco platform file generation.
Starting Cisco btldr service...
[ OK ] Started Cisco btldr service.
[* ] A start job is running for Cisco act2 check (6s / 1min)
[ **] A start job is running for Cisco act2 check (10s / 1min)[*03/10/2020 12:56:25.3824] ... rebooting now!
[03/10/2020 12:56:29.9500] reboot: Restarting system
Leo Laohoo
RMA
marce1000
 - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvj70185/?rfs=iqvred
                 Indicative , but seemingly not exactly your platform , you may try :
          https://software.cisco.com/download/home/286284738/type/280926587/release/8.10.151.0
 = current advisory release for the 5520 , check if that can help.
 M.
