3802i with 8.10.130.0 does not broadcast "CiscoAirProvision" SSID after factory reset. Keeps showing "CAPWAP State: Discovery" in console
skysurf76
From my reading I thought 8.10.130.0 was a Mobility Express firmware.  I was expecting to see the "CiscoAirProvision" SSID being broadcast after the factory reset.  Am I missing something?  How do I get the AP to broadcast the initial SSID so I can go through the configuration wizard?
Rich R
If you don't succeed you might need to open a TAC case.
I recall seeing a number of similar problems reported here previously (you can search for them) with the "not enough space" problem.  I think the solution was to downgrade to 8.5 then upgrade to 8.10.
8 Replies 8
Scott Fella
First verify if the ME image is there and when you issue a show version, that you see ap image and ap configuration as mobility express. Also you might need to erase the nvram, factory reset again and when prompted for username, enter recover-config. You might also want to check the flash and delete any config files.
-Scott
show ver gives...
cisco AIR-AP3802I-B-K9 ARMv7 Processor rev 1 (v7l) with 1028260/672796K bytes of memory.
Processor board ID FCW2201NFN3
AP Running Image : 8.10.130.0
Primary Boot Image : 8.10.130.0
Backup Boot Image : 0.0.0.0
Primary Boot Image Hash:
Backup Boot Image Hash:
1 Multigigabit Ethernet interfaces
1 Gigabit Ethernet interfaces
2 802.11 Radios
Radio Driver version : 9.0.5.5-W8964
Radio FW version : 9.1.8.1
NSS FW version : 2.4.28
I don't know how to tell if it is an ME version or ME config.
After alot of googling I cannot find a command that works to erase nvram...
AP00A7.42C8.2BF0#erase nvram
% Invalid input detected at '^' marker.
Trying recov-config at the login prompt resulted in the following... (I used Cisco as the password)...
User Access Verification
Username: recov-config
Password:
% Authentication failed
You can start here and make sure the ap is booting with Mobility Express:
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/mob_exp/810/user_guide/b_ME_User_Guide_810/getg_started.html#task_7588F4C009744AEFBB9EB754A713E390
-Scott
I tried to upgrade directly to ap3g3 firmware using tftp and it didn't work.  I then tried using ap3g3-k9w8-tar.153-3.JPK.tar thinking it was a lightweight AP and still get the same message....
AP00A7.42C8.2BF0#ap-type mobility-express tftp://192.168.5.104/AIR-AP3800-K9-ME-8-10-130-0.tar
Starting download ME-AP image tftp://192.168.5.104/AIR-AP3800-K9-ME-8-10-130-0.tar ...
It may take a few minutes. If longer, please abort command, check network and try again.
##################################### 52.7%[*06/26/2021 03:38:32.8013]
[*06/26/2021 03:38:32.8013] CAPWAP State: Discovery
[*06/26/2021 03:38:32.8019] IP DNS query for CISCO-CAPWAP-CONTROLLER.localdomain
[*06/26/2021 03:38:32.8053] IPv6 DNS query for CISCO-CAPWAP-CONTROLLER.localdomain
[*06/26/2021 03:38:32.8100] Discovery Request sent to 255.255.255.255, discovery type UNKNOWN(0)
######################################################################## 100.0%
Image download completed.
Upgrading ...
upgrade.sh: Script called with args:[NO_UPGRADE]
do NO_UPGRADE, part1 is active part
upgrade.sh: Script called with args:[-c CHECK_ME]
do CHECK_ME, part1 is active part
upgrade.sh: Start doing upgrade arg1=CHECK_ME arg2=,from_cli arg3= ...
upgrade.sh: Using image /tmp/cli_part.tar on barbados ...
Image signing verify success.
[6/26/2021 3:39:47] WARNING: Master upgrade Aborted, shadow is not good
upgrade.sh: part to upgrade is part2
upgrade.sh: AP version1: part2 , img 8.10.130.0
root: Adjusting boot partition "part2" size
[06/26/2021 03:38:51.4300] UBI error: ubi_create_volume: not enough PEBs, only 517 available
[06/26/2021 03:38:51.5300] UBI error: ubi_create_volume: cannot create volume 1, error -28
Set volume size to 65646592
Volume ID 1, size 517 LEBs (65646592 bytes, 62.6 MiB), LEB size 126976 bytes (124.0 KiB), dynamic, name "part2", alignment 1
mknod: /dev/ubivol/part2: File exists
mknod: /dev/ubidev/part2: File exists
/tmp
upgrade.sh: mount ubifs /dev/ubivol/part2 as /bootpart, status=0
upgrade.sh: Untar /tmp/cli_part.tar to /bootpart/part2...
tar: write error: No space left on device
upgrade.sh: Failed to untar: 1
Filesystem 1K-blocks Used Available Use% Mounted on
/dev/ubivol/part2 57456 57448 0 100% /bootpart
0 /bootpart/part2
upgrade.sh: Sync image to disk...
upgrade.sh: Extract image failed.
upgrade.sh: Cleanup for do_upgrade...
upgrade.sh: /tmp/upgrade_in_progress cleaned
upgrade.sh: Cleanup tmp files ...
Failed to upgrade flash..
That's just a standard CAPWAP AP.  You need to install the ME software.  Follow the "Converting from CAPWAP Lightweight AP to Cisco Mobility Express Software" process.
https://software.cisco.com/download/home/286304536/type/286289839/release/8.10.151.0
Rich R
Yep, that did it.
