09-06-2018 01:13 AM - edited 07-05-2021 09:07 AM
Hi expert out there,
Anyone have experience to power AP2802i with Normal Cisco PoE switch and without external POE injector?
I am a bit confuse with the datasheet powering option. Is that must be UPOE switch or normal PoE switch with sufficient power will do?
thanks for help.
09-06-2018 01:45 AM
"normal PoE" is 15.4w and this is not sufficient. This will only power up the AP but one of the two radios will be disabled.
2800 requires 30.0w power.
09-06-2018 01:51 AM
Hi Leo,
How about PoE+ switch? by theory PoE+ switch should be alright to power up the AP2802i right? not sure in real, will it have any problem or losses that cause the powering problem?
09-06-2018 02:35 AM
There are some switches out there that advertise as "PoE+" but can only support up to 20.0w.
As long as the switch can supply 30.0w to a port the 2800 will work.
