AP9130 running WLC software
jvadino
Community Member
I have a Cisco AP9130 that is currently configured as a LWAP.  I would like to convert this AP to autonomous, run the WLC software o it so that I can utilize it for Active Surveys at customers' sites.  I am looking for a little guidance on the best way to accomplish this.  Thank you.  -Jim
Convert to autonomous is pretty easy but you need to download the image.
https://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
However, Autonomous does not have WLC but Mobility Express which is the New autonomous.
https://semfionetworks.com/blog/convert-a-cisco-capwap-ap-to-a-mobility-express-ap/
That's all wrong @Flavio Miranda
Catalyst 9100 do not support autonomous (that was IOS based APs - the new are all COS) and ME was AireOS and only for the Wave 2 AC access points.
As @Haydn Andrews says below the Catalyst 9100 APs now run the IOS-XE (9800) based EWC on AP.
Note they don't all support EWC - for example the new 9136 does not, but it has a dedicated survey mode.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Haydn Andrews
The 9130 will need to run the EWC to do site surveys. Firstly you need to convert the AP to the EWC mode, then config the site survey SSIDs/ power levels, channels etc
Rather than me telling you how to do it there already some good references here:
Cisco Official Guide
https://www.cisco.com/c/en/us/support/docs/wireless/embedded-wireless-controller-on-catalyst-access-points/215303-embedded-wireless-controller-conversion.html
Good blog here doing this via a python script
https://semfionetworks.com/blog/configure-a-cisco-ios-xe-ap-for-an-apos-site-survey-using-python/
Good video on how to do it without the script here
https://www.youtube.com/watch?v=zqeFwL534m8
Another good blog here:
https://sc-wifi.com/2019/12/03/cisco-802-11ax-site-survey-single-ap-method/
*****Help out other by using the rating system and marking answered questions as "Answered"*****
