Apple devices keep connecting
MPribadi
I'm using C9800-CL with 17.3.7 IOS, I have issue with users use Apple devices (MacBook, iPad, iPhone). I set the session timeout for 12 hours (43200 seconds), but all apple devices never get timeout, but android and windows users will have their time out. This issue consumes our bandwidth which limited because we use volume based for Starlink.
When I saw the client monitor, I found the session timer is not running as one of the user below:
When I check, all users have the same status (session timer not running). But once again, the session timeout is working for android and windows devices, but not with apple.
2 Accepted Solutions
Scott Fella
Have you tried to disable sleeping client on your test SSID?
-Scott
Hello @Scott Fella, this is solved my problem. Even though the device seems connected to wireless:
But traffic is not passing through:
the device also removed from Client monitoring page. From show wireless client mac detail, i cannot see the mac after the timer reach 0.
xxx-vWLC#show wireless client mac 9ab9.e33d.5375 detail | in Time
Session Timeout : 600 sec (Remaining time: 17 sec)
Session Warning Time : Timer not running
Mobility Complete Timestamp : 12/13/2023 17:52:43 CET
Client Join Time:
Join Time Of Client : 12/13/2023 17:52:43 CET
Client Entry Create Time : 652 seconds
Absolute-Timer : 600
Reassociation Timeout : 20
Client Scan Report Time : Timer not running
xxx-vWLC#show wireless client mac 9ab9.e33d.5375 detail | in time
Idle state timeout : N/A
Session Timeout : 600 sec (Remaining time: 14 sec)
Session timeout : 600
xxx-vWLC#
xxx-vWLC#
Many thanks!
MP
13 Replies 13
Mark Elsen
 - Advising to go to https://software.cisco.com/download/home/286322605/type/282046477/release/Cupertino-17.9.4a ,
                 since 17.3.x is end of support ; check if that can help ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Hi @Mark Elsen, I'll try to upgrade it. Just need a permission to have a good time to upgrade and reload it. I'll let you know the result.
Hi again @Mark Elsen, upgraded to 17.9.4a. I'm still experiencing the issue.
 - Investigate further  with :
               Controller# show wireless client mac           <Apple CLIENT MAC ADDRESS> detail | inc time
        | inc Time
  (note sure if the first time after inc is case sensitive or  not)
 M.
What auth method for wlan apple connect to?
MHM
Hi @MHM Cisco World, all devices (apple, android, windows) are using the same method which is web-auth:
And I configured the web-auth as follow:
Local or central WebAuth
MHM
This is local web-auth. If they're authenticated the firewall will give the address since the DHCP server is on our firewall. This was working perfectly when we're using Cisco 3504 WLC but now it stops working for Apple product.
MP
The apple run 802.11K
There is assisted roaming 11k in advanced tab of wlan edit' select all three option and check again
MHM
Hi @MHM Cisco World, made new ssid with same configuration (different assigned vlan and ssid name of course) so I won't disrupt production network. I made shorter timeout which is 10 minutes and tried to select all three option. The issue still there. Then tried to unselect all of 3 options with the same result. Tried it on 17.3.7 and 17.9.4a IOS. Now the controller using 17.9.4a version.
When remaining time reached 0, then it returns back to 600 seconds and apple devices (tested with iphone and ipad) are still connecting to the network (until now), but windows and android devices were timeout and we need to relogin using web-auth.
MP
Scott Fella
-Scott
Client Join Time:
xxx-vWLC#
xxx-vWLC#
Many thanks!
MP
Apple devices will sleep when the screen is inactive, that is what you are seeing.  Once the idle timer is hit, the controller will de-auth the device.  Keep in mind why you have sleep clients also, because it might be something you still need.
-Scott
